603,963 active members*
3,068 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
Hybrid View
Old Timer Battery for Dynapath 20 06-16-2023, 03:18 AM
machinehop5 Re: Battery for Dynapath 20 06-16-2023, 04:08 AM
Old Timer Re: Battery for Dynapath 20 06-16-2023, 04:36 AM
machinehop5 Re: Battery for Dynapath 20 06-16-2023, 05:12 AM
Old Timer Re: Battery for Dynapath 20 06-16-2023, 02:27 PM
Old Timer Re: Battery for Dynapath 20 06-17-2023, 01:59 PM
machinehop5 Re: Battery for Dynapath 20 06-17-2023, 03:23 PM
Old Timer Re: Battery for Dynapath 20 06-17-2023, 10:25 PM
machinehop5 Re: Battery for Dynapath 20 06-18-2023, 08:16 PM
Old Timer Re: Battery for Dynapath 20 06-19-2023, 12:42 AM
machinehop5 Re: Battery for Dynapath 20 06-19-2023, 01:58 AM
Old Timer Re: Battery for Dynapath 20 06-19-2023, 03:31 PM
machinehop5 Re: Battery for Dynapath 20 06-19-2023, 06:35 PM
Old Timer Re: Battery for Dynapath 20 06-19-2023, 07:57 PM
Old Timer Re: Battery for Dynapath 20 06-19-2023, 08:08 PM
Old Timer Re: Battery for Dynapath 20 06-19-2023, 10:13 PM
machinehop5 Re: Battery for Dynapath 20 06-19-2023, 11:17 PM
Old Timer Re: Battery for Dynapath 20 06-20-2023, 12:38 AM
Old Timer Re: Battery for Dynapath 20 06-23-2023, 07:24 PM
machinehop5 Re: Battery for Dynapath 20 06-23-2023, 08:21 PM
Old Timer Re: Battery for Dynapath 20 06-25-2023, 02:41 AM
machinehop5 Re: Battery for Dynapath 20 06-25-2023, 01:44 PM
Old Timer Re: Battery for Dynapath 20 06-26-2023, 12:57 AM
machinehop5 Re: Battery for Dynapath 20 06-26-2023, 10:55 AM
Old Timer Re: Battery for Dynapath 20 06-26-2023, 02:35 PM
Old Timer Re: Battery for Dynapath 20 06-27-2023, 12:43 AM
Old Timer Re: Battery for Dynapath 20 06-27-2023, 10:18 PM
Old Timer Re: Battery for Dynapath 20 07-04-2023, 08:51 PM
    Sep 2007
    31
    Hi all. I had to retire for medical reasons two years ago, and have been trying to sell my machines and tools since then. I have a CompuMill 2500 with a DynaPath 20 controller.
    I have a guy interested in the mill who was coming over to look at it yesterday, so I went out to clean it up and make sure it ran okay. The mill has been sitting for about 14 months and the battery in the controller is dead. Great.
    The manual isn't much help, and I don't see the battery after I took the cover off. Is it under all the guts? Do I have to remove everything to access the battery? The manual says it's a 3 volt lithium, similar looking to a "B" cell. I can probably get one from the dealer who built this machine, 40-some miles away, but how much work is involved in changing it, and what do I have to set up afterwards?
    TIA!
    Aug 2009
    1573
    ...Hi Old Timer, the battery should be on the Aux board in Slot #1. It maybe a AA Type 3v (photo 2) or a battery that looks like a Cap. (see photo 1)
    Attachment 493878
    Attachment 493880
    The battery is for Programs and Offsets so, the machine should start up even if, dead battery.
    DJ
    Sep 2007
    31
    Thanks for the reply, but I have no idea what I'm looking at. Which is the battery?
    Where is the best place to buy one?
    Aug 2009
    1573
    ...I edited the Photos above reply with Red circles for possible Battery you have...The big round Cap type battery might be soldered in or plugged into the board ..I dont remember and where to buy them search Google.
    Sep 2007
    31
    Quote Originally Posted by machinehop5 View Post
    Got it, thanks! I have the flat one as in pik #1. It appears to be soldered in. I will contact the people who built the machine and will update this post if anyone is interested in these antiques.
    Sep 2007
    31
    Here's where I am so far. I let it run for a while and I can finally get the "Reset" to work and the loud relay snaps as it should. I could not do this previously.
    But no matter what I do, I cannot get off this screen, none of the buttons will do anything. (am waiting to hear back from the builder).
    Attachment 493904
    Aug 2009
    1573
    ...I was going to suggest to leave the control ON and machine in EStop for awhile might charge the battery. You say no keys/buttons are working.... you can try turning OFF the power and unplug and re-plug all the Cards/Boards, Cable plugs, etc in and out a few times. Be to sure to Ground yourself out before removing the Cards. Touching the Dynapath case to discharge any Static Elec on you.
    Sep 2007
    31
    Thanks for the tip, I will try it Monday. Do you mean just the boards in the controller?
    Aug 2009
    1573
    Quote Originally Posted by Old Timer View Post
    ...The board with the Cable going to the Operator's Panel/MTB interface board is the main one to check. Slot #6 ( I think). Also, if you want to replace the Battery yourself they are available many places. Mouser has them.
    https://www.mouser.com/ProductDetail...vvV1GmUQ%3D%3D
    DJ
    Sep 2007
    31
    DJ
    Somewhere here?
    Attachment 493940
    Attachment 493942
    Aug 2009
    1573
    ...bingo. It's on the "Auxiliary" board Slot#2 looks like "MTB INTERFACE" plug circled in red.
    Attachment 493946
    This is the MTB (Machine Tool Builder) board pictured below photo....the Pins on the green plugs are not gold plate so, unplugging and plugging them in and out also a few times. But, the big MTB Cable needs to be checked mainly.
    Attachment 493948
    ...Hope this fixes the Keypad problem....If not, what exactly is coming up on your Screen at Bootup?
    DJ
    Sep 2007
    31
    On boot up:
    Attachment 493952
    Got the rear cable off, can't access bottom screw on front connection, can't even see it. I did loosen the top screw and wiggled the connection some.
    Attachment 493956
    This is the first time I've seen this screen:
    Attachment 493954
    But it bounces back and forth with this screen. Pushing the fault button does nothing, nor can does hitting e-stop and Reset do anything.
    Attachment 493958
    Aug 2009
    1573
    ...looks like the Battery needs to be replaced 1st, before we can do anything more. Hitting the RESET should have cleared the Fault screen, then should be able to view Fault Message.
    Sep 2007
    31
    Yep, that's how it used to work.
    Sep 2007
    31
    The battery from your link looks the same as I have. My machine manual says it's 3 v, that link says 3.6 v. Does it matter? Is it soldered in?
    EDIT:
    I just looked up "axial leads," and see that it is apparently soldered into the board.
    Sep 2007
    31
    I got all those leads off, and pushed them on and off several times. At first boot it doesn't do anything other than tell me I need a new battery.
    After running a while, I can get the e-stop and reset to snap back and forth, and then it tells me again that I need a new battery, no other screens available. Sounds like the battery is charging enough to make a few things work, then dies again when I shut it down overnight.
  17. #17
    Aug 2009
    1573
    ...leave the Control ON and yes 3.6vdc is standard battery TL-5135 or the number is on your battery. Also, make note of +(plus) and - (minus) on the battery if, it's not marked on the board MARK IT
  18. #18
    Sep 2007
    31
    You mean leave the control on now? Or after I change the battery?
    That link said the battery is not rechargeable, I thought they were. Oh well, I am going to order it tonight.
    EDIT: Battery ordered, supposed to get it Thursday.
  19. #19
    Sep 2007
    31
    Battery is coming this afternoon via UPS.
    I've got the board out and here are pix of the battery and the backside. I see a + on the face of the battery but that's all. I've got to find a TV guy or somebody around here to replace this, no way am I going to attempt it. I'm good at soldering plumbing or electrical wires, but I ain't touching this.
    Attachment 494128
    Attachment 494130
  20. #20
    Aug 2009
    1573
    ...looks like this battery has three pins so, + and - can not get mixed up. No problem there. Good luck finding a TV repair guy...
    I'm near Omaha, NE if, I can help.
Name:	TL-5135 Battery.jpg
    DJ
Page 1 of 2 12
  1. Replies: 13
    Last Post: 03-13-2025, 09:01 AM
  2. 2100 NCK ALARM 810D - NEED TO CHANGE BATTERY - WHERE IS THE BATTERY LOCATED?
    By scottbryce in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 09-22-2021, 07:35 AM
  3. Need HELP! Dynapath delta 40M battery problem
    By looey_bj in forum Dynapath
    Last Post: 01-16-2014, 01:22 AM
  4. Centroid M-400 CMOS BATTERY LOW VOLTAGE FAULT- WHERE IS THE BATTERY?
    By Russ Shugg in forum Centroid CNC Control Products
    Last Post: 01-11-2014, 03:01 AM
  5. Dynapath System 10 PSU Battery
    By islander261 in forum Dynapath
    Last Post: 08-20-2013, 06:33 PM
