603,855 active members*
3,838 visitors online*
Results 1 to 6 of 6
    Sep 2009
    19
    Question Baud Rate for Fanuc System 6T
    I need to know the baud rate in Fanuc 6T.on Cnc Hitachi seiki 5Ne 11000,using mastercam program.
    thanks in advance.
    Feb 2006
    992
    You need to check the machine want to communicate with it's under In/Out page, and you can setting your DNC match that number, I don't think anyone can tell you what the machine is have.
    The best way to learn is trial error.
    Dec 2003
    24260
    Check parameters 0024 & 0025.
    0024 is bit 0 = 0 is 1 stop bit, bit 0 = 1 is 2 stop bits.
    0025 is the baud rate 2400 baud is 11001111, 4800 baud is 11101111.
    Al.
    Albert E.
    Sep 2009
    19
    tHANKS, Mr.AL. WAS VERY helpful !!!! KNOW IF IS POSIBLE, I have doubts on the communications of Mastercam (Pc) to the machine, ...How to know the
    1.FORMAT (THE OPCIONS ARE : ASCI,EIA,BIN)
    2.PARITY (THE OPCIONS are: Odd,Even,None)
    3.Data Bits(The opcions are:6,7,8)
    4.Handshaking(None,sofware,Hardware)
    Thanks again!!!
    Dec 2003
    24260
    This may help also.
    Try this program.
    http://www.cadem.com/free_dnc_drip_f..._machining.htm
    Al.
    Attached Files Attached Files
    Albert E.
    Oct 2007
    179
    The max baudrate on Fanuc 6 is 9600.
    John.
  1. What RS232 baud rate do you use? and why?
    By gar in forum Haas Mills
    Last Post: 07-24-2012, 01:51 AM
  2. Getting higher baud rate in V23
    By kbspeed in forum BobCad-Cam
    Last Post: 08-11-2009, 09:54 PM
  3. Whats Maximum baud rate on an OM-D
    By meadowtech in forum Fanuc
    Last Post: 02-21-2009, 06:17 AM
  4. V-22 baud rate
    By qualitytool in forum BobCad-Cam
    Last Post: 10-20-2008, 02:11 PM
  5. Fanuc O-T baud rate
    By ttorqueshop in forum Daewoo/Doosan
    Last Post: 12-13-2007, 07:57 AM
