603,539 active members*
3,804 visitors online*
Results 1 to 7 of 7
    Feb 2004
    14
    Bearing shaft
    All I have is a rough PDF sketch of what I need made. I am looking for it to be made from 303 Stainless. Please PM me with quotes, thanks!
    Attached Thumbnails Attached Thumbnails Shaft.pdf
    Apr 2013
    99
    Re: Bearing shaft
    You want 1 or 100?
    only hard thing on that is the threw hole.
    gun-drill it ream it then turn between centers to make it concentric
    and cut the keys.
    probably cost you around $100 at your local shop.
    no I don't want to make
    but that's how you would do it
    Feb 2012
    55
    Re: Bearing shaft
    Does this part get welded at all? If not, recommend 303SS instead of 304SS.
    Does the through-hole need +/-.005" all the way through? That single feature will cost more than all the rest of the work.
    Regards.
    Mike
    Aug 2010
    107
    Re: Bearing shaft
    He says 303 stainless in his post, which is what I would go with, but in his drawing he says 304 with a question mark. So I think he figured out 303 bearing shaft is what he wants.
    ToolMaker please edit your private message settings to accept private messages or post your e-mail address, thanks.
    Feb 2004
    14
    Re: Bearing shaft
    Quote Originally Posted by azmachining View Post
    Yeah, I changed it to 303SS in my post, please disregard what the print says there. My private message settings are ok to receive from everyone, did you have an issue with it? I suppose the .800 through could be +/- .010 and still be fine. I have the option of making that dimension .750 +.010 / -.000 if that's easier?
    Edit: Forgot to say I only need one.
    For email you could try" nyboltfan AT Yahoo dot com
    Thanks guys.
    Apr 2013
    99
    Re: Bearing shaft
    It's the depth that makes it hard, drill bits wander,
    .750 +.010/-0.000 is much easier.
    once you have it drilled it's maybe 1/2 hour on the lathe and about the same on the mill to cut the keys
    Aug 2010
    128
    Re: Bearing shaft
    .755 +/- .005 is easier than .800 +/- .010 ?
  1. CLEARENCE BETWEEN SHAFT & PLAIN BEARING
    By Ashish B in forum Linear and Rotary Motion
    Last Post: 12-13-2010, 06:38 PM
  2. shaft support bearing placement
    By dsc in forum Mechanical Calculations/Engineering Design
    Last Post: 11-29-2009, 10:53 PM
  3. What is the grade of linear bearing shaft
    By garagefela in forum Linear and Rotary Motion
    Last Post: 08-02-2006, 02:53 PM
  4. Shaft and bearing fit question
    By nervis1 in forum MetalWork Discussion
    Last Post: 10-31-2005, 03:33 PM
  5. Bronze Flange Bearing and Alu Shaft - Ok?
    By creative_mind in forum MetalWork Discussion
    Last Post: 09-18-2004, 06:01 PM
