603,939 active members*
1,666 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Before I do this the hard way.... 3d printing parts from an assembly.
    Mar 2015
    53
    Complete fusion 360 newbie here...
    I have a single fusion 360 assembly drawing, with many constituent parts (bodies).
    What is the easiest way to get all the parts layed out into an stl file for 3d printing? Just go through the assembly tree and do a save as mesh on each body?
    Or does fusion 360 have a tool that will give me a single stl file with all the parts neatly laid out in the correct orientation for printing?
    Cheers!
    Jun 2012
    182
    Re: Before I do this the hard way.... 3d printing parts from an assembly.
    Organize the parts so the bottom of each is on the same plane. The Arrange command may work, otherwise you can use planar joints if individual parts are components (and they should be). If all of the parts are not on the same plane, I would create a new component, then Copy/Paste each part into the component as subcomponents. Use the Save As Mesh command on the parent component.
  1. Toolpaths for 2x parts / assembly?
    By viroy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-22-2013, 09:27 AM
  2. CREATING NEW PARTS IN ASSEMBLY
    By camunderdog in forum Solidworks
    Last Post: 04-08-2013, 08:20 PM
  3. 3D printing functional gear assembly
    By todd71 in forum Videos
    Last Post: 04-04-2009, 04:10 AM
  4. Printing on hard surface tile?
    By jeffterm in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 10-01-2004, 11:32 PM
