603,988 active members*
3,180 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Beginner Tapping Confusion
Page 2 of 2 12
Results 21 to 22 of 22
  1. #21
    Jun 2008
    1838
    Mike
    G84 and G74 are indeed all that is usually needed to tap on most CNC Mills, however it does all depend on just how the MTB have setup their control to work with rigid tap.
    If what you say is correct then the HAAS must be permanently in rigid tap mode if the option is available and is probably a "macro" that is called whenever any tap command is introduced so the basic G84/G74 tapping cycle will run as rigid tap.
    I put the info up as most machines I have worked on have been set so that if the rigid tap "option" is enabled it still has to be "called" by a G code in the program, this has both advantages and disadvantages but is the usual way of doing things that I have come across.
    It may well be different if the tapping cycle is input at the machine control as it is as far as I know semi/full conversational.
    As I said before I don`t have a HAAS so I was only assuming, to be certain I would need the HAAS manual for the machine
    Keep reading the Manuals
    Regards
  2. #22
    Apr 2009
    3376
    ""The post modification I mentioned was to change BobCADs way of posting feed. I could not get it to work with IPR, so set it to IPM and it was good.""
    Hey,what do you know it computes in V25.Like I said I always use manual tools for everything,BUT,it does not wurk in V23.Machineit does it wurk in V23 for you?Or do you have that?
Page 2 of 2 12
  1. Replies: 13
    Last Post: 07-04-2009, 12:43 AM
  2. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  3. G52 confusion
    By davek in forum G-Code Programing
    Last Post: 09-08-2007, 02:01 PM
  4. confusion
    By serry in forum DIY CNC Router Table Machines
    Last Post: 04-28-2007, 12:40 AM
  5. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
