587,281 active members*
3,443 visitors online*
IndustryArena Forum > MetalWorking > Bending, Forging, Extrusion... > bending a spiral out of alum square stock
Results 1 to 4 of 4
    May 2007
    327
    I need to make a fairly dense spiral 10 revolutions. with about .25" between walls. can someone suggest a way to do this? thanks.
    R.
    Aug 2010
    Question
    Sure, make a very expensive mandrel. Which might be a bit price prohibitive depending on the quantity you actually need?
    That or source it out: http://www.falconindustries.com/conveyor_screws.htm
    Regards
    The Manufacturing Reliquary
    http://cmailco.wordpress.com/
    Mar 2004
    439
    You don't mention the cross section of the material, but if it is not too stiff, and you have a heavy duty lathe, (with a very slow speed) you could wind it like winding a custom spring. You can wrap it around a threaded mandrel at your desired pitch, or wind it with a "spacer" like this:
    http://chestofbooks.com/home-improve...il-Spring.html
    Keith
    NEATman
    Basic research is what I'm doing when I don't know what I'm doing. Wernher von Braun
    May 2007
    327
    thanks for advise i think i found a bendable plastic alternative.
  1. Bending 1/8" square Stainless Bar Stock
    By Bingster in forum Bending, Forging, Extrusion...
    Last Post: 09-01-2009, 03:11 PM
  2. Bending square tubing steel
    By MBG in forum Bending, Forging, Extrusion...
    Last Post: 08-02-2009, 05:40 PM
  3. Machining square stock on a CNC lathe
    By premier_industr in forum MetalWork Discussion
    Last Post: 05-03-2009, 07:25 PM
  4. Centering square stock with a 4-jaw chuck
    By farmboy in forum Uncategorised MetalWorking Machines
    Last Post: 04-26-2009, 06:06 AM
  5. Bending a closed box tube from flat stock
    By z28tt in forum Bending, Forging, Extrusion...
    Last Post: 12-07-2006, 08:05 PM
