588,522 active members*
7,858 visitors online*
Thread: BENT SHAFT
Results 1 to 4 of 4
    Jan 2006
    37
    BENT SHAFT
    Here is the job at hand .
    2inch square 1018 CF material 72 inches long .
    Need 6 inch journals on both ends that are 1.438 in diameter.
    Need minimal axial runout . As in None.
    Have a ten foot machine but the material is any thing but straight and im getting run out on th journal no matter what i do .....
    Bettween centers ,four jaw, ........AKKKKKK my 23 years cant make this work ....LOL some ideas would just be graetly apreciated:banana:
    May 2004
    4519
    You can't put 6 journals the same diameter on the end of anything. They would merge into 1 journal. What are you using as the reference point to determine run out? Do you mean the journal is not round to itself? Do you mean each journal is not running true to an adjacent journal? What is the width of the journals? What is the distance between the journals?
    1018 will probably stress relieve. Recommend hold material close with 4 jaw and center drill. Then hold material long with center in tail stock and rough machine all journals to 0.030" over. Then rough machine all to 0.010" over. Then finish machine all.
    Sep 2006
    6463
    Quote Originally Posted by txcncman View Post
    What he means is bro, the journels are 6" long on each end and 1.438"diam.
    Didn't you read the post?
    On a job like this you first need to drill centres on the ends , and they can just be marked out and drilled with a conventional drill, just to get them into the ends of the bar.
    Then you can machine the journals between centres the normal way, taking care not to go too fast or the bar will vibrate and spoil the finish.
    Ian.
    May 2004
    4519
    No. I did not read it.
  1. How is a shaft attached to a shaft support rail ?
    By Power_user_EX in forum DIY CNC Router Table Machines
    Last Post: 06-16-2012, 12:03 PM
  2. Bent Too Much?
    By Mr.Chips in forum DIY CNC Router Table Machines
    Last Post: 02-20-2009, 05:25 PM
  3. Bent Exhaust Valve
    By Soultaker696 in forum Bending, Forging, Extrusion...
    Last Post: 08-12-2008, 04:18 AM
  4. Looking for a Coupling for 1/2" motor shaft to KR33 6mm shaft
    By DonW in forum DIY CNC Router Table Machines
    Last Post: 03-17-2008, 09:58 PM
