Working Videos:
Advantage of EagleTec 4 Axis CNC Foam Router For 3d Polystyrene Shapes
• The equipped spindle is a high torque & big power HQD automatic tool change spindle, with ISO30 tool holder. Can hold tools with a maximum diameter of 20mm. Spindle is 4 axis, can swing ±90°.
• Z-axis stroke of 4 axis cnc foam router is up to 1000mm, and the load is relatively heavy. To ensure fast and accurate positioning, we designed dual pneumatic counter-balance for Z.
Z axis is driven by Delta servo 1,300w motor with holding brake, transmission way is via precise ballscrew.
• Also has a 4-axis rotary axis.
Quick Details of 4 Axis CNC Foam Router for 3D Polystyrene Shapes
• Working size 2000x3000mm (6.5x10 feet)
• Z working size 1000mm
• Rotary working size 1000x3000mm
• HQD 9.0KW ATC spindle, air cooled (can swing ±90°)
• Delta servo 1800w on X & Y, 1300w on Z
• Linear guides 35mm
• SYNTEC cnc controller (bus master)
• Steel working table
• Net weight 8,000KGS
Best CNC Foam Router with 10+ Years Experiences
