587,157 active members*
4,726 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Best belt drive ever! (If I do say so myself)
Page 6 of 19 4567816
Results 101 to 120 of 370
  1. #101
    ServoBelt and Gearheads
    Hi. You've got it correct. We generally scale up the motor to a maximum of a NEMA34-4 stack to get a peak force of 150 lbs linear. Keeping it direct driven preserves our near-zero backlash.
    For use of smaller motors, a gear head is required, which as you say, adds some backlash, but not an appreciable amount of "springiness".
    Our standard belting for ServoBelt is T5mm pitch, 32mm wide, so our recommended minimum pulley size is 15 teeth, for a linear travel of 75mm per motor rev.
    Gearheads are readily available with 6 arc-min backlash, which at our pinion size translates into only .0008" on the linear. Not too shabby. You can get up to 10:1 in a single pass planetary to get that low backlash. Higher ratios/muliple passes (usually) makes for higher backlash. If you design your own, then smaller belt pitch is allowable, which on a 3mm HTD or T series can get you a smaller pinion.
    Hope this helps!
  2. #102
    Mar 2003
    35538
    I've been playing with a design using a 3:1 belt direction driving a 13 tooth T5 pinion with a 570oz Nema 23 stepper. Forget the results right now, but thought I'd get around 100lbs of force, even at over 500ipm speeds.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  3. #103
    Cool, Jerry. I'd love to see some pics!
  4. #104
    Mar 2003
    35538
    http://www.cnczone.com/forums/showpo...&postcount=171
    Still a few months away from building a mock up.
    Edit. Added another image.
    Gerry
  5. #105
    Neeto. I LOVE skate bearings.
  6. #106
    Apr 2005
    462
    Mike, what exactly is the purpose of two rows of tensioners? Wouldn't one row on each side suffice?
  7. #107
    what's not shown in the illustration is the static belt "rack" that this all pushes on. the two rows each side doubles the number of teeth being used in shear, to make the linear force.
  8. #108
    Apr 2005
    462
    no, I was fully aware of the "rack" belt, just didn't know why two rows of "tensioners" instead of just one but that makes sense, more teeth, stiffer. maybe the question should've been why two different SIZES of tensioners rather than two rows. another question if I may, you mentioned earlier on that the top "belt" belt should be flapping about and the lower "rack" belt should be fixed (with double sided sticky tape) onto the surface. correct? would just sandwiching the two belts together and clamping them onto the surface have negative effects?
  9. #109
    The rollers have little to do with tension, rather they are there to keep the upper belt engaged with the lower, as close to the pinion as we can manage. They are different diameters because the nearest ones to the pinion force the belting to back bend, and there is a minimum diameter for long life, just as there is on the pinion itself.
    As to clamping the belts, I'm not sure I understand which way you mean that...
  10. #110
    Jan 2005
    29
    Mike,
    I love your idea / concept. I read thru this thread and I am VERY impressed with your design. I am assuming that you are not selling the belting / pulleys yet to us DIY’ers and I looked at some of the links posted to the other manufacturing companies but it appears that although it works, is it true it doesn’t work as good as your set-up? (backlash?)
    I couldn’t help but to start thinking about a system that might give you more raw thrust (milling?) would be to machine the lower track out of aluminum, let’s say in 2’ increments, that would bolt down similar to a rack and pinion set-up. This track could then be machined to fit an industry standard (XH, L, XL, etc….) belt that is readily available.
    If this (by any chance) is available (even on a trial basis!) for sale, please PM me!
    I’d love to be your guinea pig!
    John
  11. #111
    Mar 2004
    439
    John-
    If you want to make a version of this using a metal rack, you could use multiple sections of belt clamp - such as these extrusions:
    http://www.brecoflex.com/index.php?C...ID=3&SMENID=14
    However, I think that the stiffness is more defined by the section of belt that is not engaged with the rack than what the rack is made from.
    Plus, I have seen this device in person, and it is very cool watching it zip at insane speeds back and forth.
    Keith
  12. #112
    Jan 2005
    29
    I agree in regards to the section of the belt that is not engaged is the weakest link. I am also assuming (and I may be totally off base!), that the belt itself being made of polyurethane could be the weak link as well. I think this belt is selected because the belt “times” with itself when meshed and most industry standard belts do not. If the aluminum base was machined to a stronger belt pattern that for example would not mate to itself, but could mate properly to the machined aluminum (stationary) belt, you could get the same effect but with the benefit of the stronger belt and the stretch would be less.
    Just a thought……….
  13. #113
    Jul 2007
    1602
    From previous posts by Mike there are at least a couple of factors that come into play for the belt choice. One as you mentioned is that the belt profile can mesh with itself, another is that the belt can bend backwards i.e. many belts can't wrap around a roller teeth out without self-destructing.
    I am not sure that making the fixed rack out of aluminum would buy you all that much compared to the expense. There is only a very small part of the rack in play and handling load at any given time probably 3-5 teeth either side of the point where the belt comes off the rack to form the loop. Note also that the only part of the belt that is subject to stretch at any given time is that part that isn't engaged with the rack.
    bob
  14. #114
    Mar 2003
    35538
    Quote Originally Posted by Hi-Vac View Post
    Just a thought……….
    The stretch would be the same, because it can only stretch where it goes over the pinion. There's no tension on the majority of the belt.
    Gerry
  15. #115
    Hi Guys, good comments all! You're making it so I don't have to respond at all, ha ha.
    Agreed that the stiffness of the static belt is not the primary issue. Deflections there are second order for sure.
    An issue not covered before, and has come out in repeatability/velocity error testing recently is due to the loading/unloading of the downward legs of dynamic belting, even though they are preloaded by belt tensioning.
    It's not just the stretching of that short bits of belt, but that the unloading leg exhibits a little curvature until the tensioned leg achieves full commanded acceleration (tension).
    It's not much, but visible. I'll take and post up a high speed video to illustrate.
    And, hi Keith!
  16. #116
    Apr 2006
    7
    VERY cool system.
    VERY long time since you first mentioned DIY sales.
    I've been reading this thread waiting for pricing information.
    I've got a new prototype machine to build NOW.
    So....is there any DIY/small quantity pricing?
  17. #117
    Quote Originally Posted by billblack View Post
    VERY cool system.
    Sorry, still not set up for it.
  18. #118
    Apr 2006
    7
    OK, Mike.
    Thanks for the honest answer.
    I was hoping to give your system a try, but I guess we'll go a more conventional route on this new build.
    Good luck to you, sir.
  19. #119
    ServoBelt Router
    My ServoBelt Router is coming along! Base frame should be done soon.
  20. #120
    Sep 2005
    1195
    Hello Mike,
    Do you plan to sell linear servo belt kit for router? How good this kind rubber for plasma applications due to heat and a lot of debris? Thanks.
  1. Belt drive or direct drive?
    By VegasRhino in forum Drilling- and Milling Machines
    Last Post: 10-10-2013, 12:12 PM
  2. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  3. X2 belt drive
    By eartaker in forum Benchtop Machines
    Last Post: 07-07-2010, 08:26 PM
  4. Belt drive or direct drive?
    By rholliday in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2009, 12:21 AM
  5. Need Sherline Belt & qestion on X2 Belt Drive?
    By Oldboy in forum Benchtop Machines
    Last Post: 03-06-2008, 07:42 AM
