588,227 active members*
4,779 visitors online*
Page 3 of 3 123
Results 41 to 48 of 48
  1. #41
    Mar 2017
    926
    Re: Best diy z-axis designs?
    Quote Originally Posted by louieatienza View Post
    It is normally, but because different high end machines have different functionalities, they can require some custom codes and such. That's what the post-processor in CAM is for. Vectric has many, as does OneCNC (incuding post processors for Heidenhain, Haas, Okuma, FANUC, as well as Mach3). On the very high end of the CAM market, you may have to purchase a post processor separately. I know at least with OneCNC they will work with you of there is a machine not listed. If you saw the g-code for a Biesse router you'd probably go WTF, compared to the standard RS274/NGC code (which I believe FANUC controls can read, as well as LinuxCNC.)
    It's a safe bet as almost everything related to CNC has me going WTF. It happens every time I find out the price of a part.
  2. #42
    May 2005
    3920
    That was spoildbrat's build? Pretty epic. But even then, he had a lot of debugging if I remember correctly. A problem with the Galil board and Yaskawa servo drives?
    Debugging is a fact of life when it comes to machine tool building. Newbies should expect to have to do some mechanical and elecrical debug with a new machine build. The old hands on this forum take that for granted but we should help the newbie to avoid underestimating what is required to finalize a machine.
  3. #43
    May 2005
    3920
    Quote Originally Posted by Goemon View Post
    So G-code is not used with high end machines? I thought it was becoming a universal standard as so many cad/ cam software packages seem to output to it.
    The DIY world for the most part emulates FANIC and NIST "standards". As for the NIST, much of LinuxCNC came from a project there, as such many DIY GCode interpreters try to emulate the behavior of LinuxCNC which is very very close to FANUC behavior.
    Beyond that all bets are off. Basic GCode ends up being similar but beyond that you can have all sorts of specialized functions.
    I can see why custom software would be needed for non-standard machine configurations with multiple cutting tools in a production line / automation environment. I have seen companies make huge savings with custom in-line equiptment.
    At work almost everything i work on is custom except for the injection molding machines. Robots for instance can be GCode based ( very similar) or something completely different. Multi axis controllers for packaging machines can be GCode based or not. Frankly i find CNC (GCode based) motion controllers to be easier to work with than some of the solutions that use PLC programming and bus attached motion controlers.
    This can be compared to motion controlers that are programmed in BASIC like languages. The languages are very similar to BASIC but obviously isnt BASIC as we know it from the PC world. Further these languages are almost never compatible from one controller manufacture to the next. In a nut shell every manufacture goes his own way but trys to produce a somewhat familiar language.
    In the end GCode is probably more portable than many motion control solutions out there. Portable in the sense that you as a user can easily move from one platform to another.
  4. #44
    May 2005
    3920
    I think we mostly agree. My point on whether a machine makes goods for resale or not is about factoring in when and if it will deliver a return. IMO and person would have to be an idiot to spend $100,000 or $200,000 on a machine for a new business if it wasn't specifically revenue generating in quantities that made sense. In this respect, I think you have to consider what it will be used for to decide if the expense is worth it and what level of machine is actually needed.
    Ive seen companies spend millions on entire production lines that never made a cent. These lines then get sold off to scrapping companies for a few cents on the dollar. Companies do crazy things.
    Frankly $100,000 for a CNC machine is peanuts these days. Sometimes as a business you need to gamble that you can find the money/business to succeed. This especially if you want to grow a business.
    Clearly a different level of expenditure is need for a heavy 24/7 continuous use production machine vs a small prototype of hobby machine making a few parts here and there.
    Prototyping labs are a good place to try to score used machinery as yhey are often lightly used and higher end machines. Sometimes you need a machines specific capability even if it won't pay for itself in the usual way.
    In my case, a CNC machine might save me a little time but it is unlikely to increase my income sufficiently to justify a 6 figure investment at this stage.
    This is why job shops exist!!! You just have to be willing to pay for their services.
    I didn't realize that high end CNC machines all ran custom software.
    I wouldnt say all do! However the major suppliers of CNC controllers all have compatibility issues to some degree. Given enough volume or the desire to implement advanced features companies will consider DIY controllers and these can drift away from standard GCode significantly.
    I thought they used expensive but mostly off-the-shelf control boxes and drivers made by brands like Fanuc and Mitsubishi.
    Lots of machine tools are built with such hough i wouldnt call them expensive. Each though implements its own dialect of GCode.
    You're obviously someone with a lot of experience of using both high end machines and smaller homemade devices. If you tell me that making a machine of comparable quality with a $150,000 budget is not possible then I believe you. If someone with your experience could not do it then nobody could.
    What you can do as an individual depends upon your resources and how you value your time. For example you won't build a high end machine unless you own a machine shop that is well equiped or have access to one. That right there has a major impact on machine cost. It is simple things too, high end machines are heavy which means having equipment to handle that material. There are many things that we safely ignore on a low end machine that really impacts ones ability to produce a high end machine.
  5. #45
    Jan 2005
    15362
    Yes that was the only mistake on that build was the Galil control, as soon as he got rid of the Galil control, for the smoothie Board all was flying
    This was a person that had no experience in building a machine like this, he designed the machine, had the frame built in China, the rest he mostly did himself, he learned how to use a milling machine, I worked on some parts of the machine, and yes it cost a lot around $60k, the machine payed for it's self, very quickly though
    When you look at the component costs he did not cheap out on anything, each gearbox $2,600.00 x 3, Ground Helical Rack and pinion Yaskawa Ac servos, BT30 Spindles ( 2 ), the list goes on, the pinion in this photo tells you what kind of build this was, with built in lube supply, the build is 95% all steel construction, and can run at 2600 IPM rapids test cuts where at 500 IPM
    Mactec54
  6. #46
    Apr 2009
    5516
    Quote Originally Posted by wizard View Post
    Yes machines are sometimes bought on venture capital. For established business the cost of the machine is amortized over its service life, and the depreciation as deductions. Usually the company has funds set aside for capital investments, and has figured out their ROI. Sometimes the machines are financed or leased.
  7. #47
    May 2005
    3920
    This is all true for well managed companies. On the other hand I've seen really strange things happen in large business. For example R&D operations spending huge sums on 3D printing technologies that spend most of their days idle. Lathes and mills just sitting idle in the same department. Meanwhile at the other end of the building the machine shop, doing world class optical tooling, has a extremely tight budget and staffing. Sometimes companies just don't care if a project, tool or whatever is justified in any economic sense, it isn't so much venture capital as it is free spending that the rest of a company never has access to.
  8. #48
    Dec 2011
    45
    I'm pretty fond of my simple easy z axis I hacked together. The panels are 1/2" Baltic Birch ply. The first panel is supported by the linear guides and the second one the router is attached to is supported from flexing with some 1.25" square steel tube tapped and threaded to the back of it. This is incredibly stiff I have no play anywhere and I have to say I see no reason to remake these plates out of aluminum in the future, this is more than adequate
    Attachment 383518
Page 3 of 3 123
  1. Robotics - designs- miniature 6 axis module for Mendel
    By vizion in forum Mechanical Calculations/Engineering Design
    Last Post: 04-15-2011, 08:45 PM
  2. Campbel Designs THC300 & Xylotex 3 Axis HT
    By Redline in forum Waterjet General Topics
    Last Post: 08-21-2006, 04:31 AM
  3. Q: Y Axis - Gantry vs. "bridge" designs
    By Zoid in forum DIY CNC Router Table Machines
    Last Post: 07-06-2004, 10:35 PM
  4. Alternate Z-axis designs
    By chuckknigh in forum DIY CNC Router Table Machines
    Last Post: 04-29-2003, 07:24 PM
