588,563 active members*
5,056 visitors online*
Results 1 to 8 of 8
    Jul 2006
    65
    best drill bit
    G'morning all
    I'm looking to drill 5/64" holes into 3/8" thin wall stainless steel tubing, I picked up a couple of DeWalt Titanium Split Point bits. The way I have it set up is with the bit all the way up in the chuck so only about an inch is coming out of it. I need advice on the best type of bit for the job as mine are basically just polishing the surface.
    Gary
    Nov 2007
    479
    Re: best drill bit
    On stainless, I usually go with Precision Twist cobalted screw machine drills. 30-60 sfm, .004 per rev. 2000 rpm is a good starting point, keep it feeding and use oil for lube.
    Mar 2014
    19
    Re: best drill bit
    .004 IPR on a 5/64" drill is not s good idea. I would definitely stay away from all dewalt drills as well.
    Decent brand cobalt screw machine drill with 40sfm and about .0013 IPR will get you a bunch of holes.
    Jul 2006
    65
    Re: best drill bit
    Thanks guys
    Urgh, what is IPR and 40sfm? Also, I can find out the hard way and spend bucks n time so, Any brand names I should follow?
    Thank you
    Mar 2014
    19
    Re: best drill bit
    Are u doing this with a machine or hand drill?
    Jul 2006
    65
    Re: best drill bit
    Actually mate I'm using a lil ol Dremel 4000 on a 220 work station with an attached vise. I thought it would be good for a small hole on thin wall ss tube O.D 3/8"
    Mar 2014
    19
    Re: best drill bit
    Ok.
    SFM = surface feet per minute
    Spindle speed = (SFM*3.82)/tool diameter
    Using 40sfm u would get 1959rpm for a .078 dia drill
    IPR=Inches per revolution
    IPM=IPR*spindle speed
    Using .0014 IPR you get 2.7 IPM
    So run at 1959 RPM at 2.7 IPM.
    NOW, something is telling me your not using a spot drill to get this hole started. You MUST use something to keep the drill from wondering down either side of the tube. Unless you were ABSOLUTEY dead nuts center on the tube, that flimsy little drill will just deflect away and probably snap.
    As for drill selection... You should be fine with dewalt brand drills if you plan on just drilling 1 hole. If you are doing a lot of holes step it up to a metalworking brand drill. I prefer YG1 brand drills myself. You can get them pretty cheap at suncoasttools.com or in eBay.
    Jul 2006
    65
    Re: best drill bit
    Wow Nodeco, thanks for the heads up mate, I've got the basic but gotta give this one some more thought. Being really really new at this this and to be totally honest, I originally thought it was place the bit in the chuck and position the ss tube and drill. So, I really do appreciate the education.
    Have a g'night mate
  1. How to drill a deep hole using U drill on floor boring machine
    By SatishNaik in forum News Announcements
    Last Post: 10-15-2013, 12:58 PM
  2. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
