603,936 active members*
4,173 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Best ethernet controller options out there....
Results 1 to 9 of 9
    Jan 2007
    37
    Currently using Geckodrive GREX G100 with Mach3. Works great except for 2 minor issues such as tool change auto-zero and reffing all axes simultaneously.
    What I like about GREX G100 is that it has ethernet and 6 axis support already built in. It's too bad it was discontinued.
    Are there any Mach3 supported ETHERNET controllers which can support 6 axis right out of the box?
    G540 with EthernetSmoothstepper can support 4 axes easily, but if 2 other axes are needed it seems that the only way to do it is to add a separate breakout board.
    Perhaps there are some other alternatives....
    Mar 2003
    35494
    Re: Best ethernet controller options out there....
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jan 2007
    37
    That's all there is? $549 euros is kinda steep. That's $760 USD.
    What about ethernet smoothstepper?
    Mar 2003
    35494
    You asked for the best ones.
    The Smoothstepper is the most popular.
    The CSMIO/IP-S and Vital Systems Hicon are probably the best two. Also the most expensive.
    Gerry
    Jan 2007
    37
    Gerry,
    GREX G100 was also expensive back in the days... It was $399.
    Which would you consider better among the two you listed? CSMIO/IP-S or Vital Systems HICON? Hicon Integra looks sweet and it seems like it has Mach4 support.
    Mar 2003
    35494
    I'm not saying that they're good because they're expensive. They just happen to be the most expensive.
    All I can go by is what I've read. Everything I've read about the CSMIO IP-S is that it's outstanding. If nothing better comes along, it's what I'll be using on my new router.
    I haven't read much at all about the Hicon, but I've also heard great things about Vital systems other products. I don't think you'd go wrong with either one.
    Both will have Mach4 plugins at some point. If not when Mach4 is released, I suspect both will be very soon after.
    Gerry
    Jan 2007
    37
    Gerry, which features of CSIO IP-S make it better than Vital Systems integra? did you compare the two units side by side?
    Mar 2003
    35494
    I don't think I said it was better. I just know quite a few people who's opinion's I value that are using the CSMOIO, and I don't know anyone using the Hicon Integra.
    It does have more I/O, though.
    I think they are probably both very comparable.
    Gerry
    Jan 2007
    37
    Thank you for your input Gerry.... You are always helpful and your screenset rocks!
  1. CNC Ethernet Controller Recommendations
    By bmellis in forum Australia, New Zealand Club House
    Last Post: 02-28-2017, 09:26 PM
  2. Which USB/Ethernet motion controller for a laptop?
    By ChrisAttebery in forum Mach Software (ArtSoft software)
    Last Post: 05-06-2013, 12:01 AM
  3. CSMIO/IP-S Ethernet Motion Controller (CNC)
    By CNC support in forum News Announcements
    Last Post: 10-26-2011, 10:57 AM
  4. Replies: 3
    Last Post: 01-15-2011, 12:19 AM
  5. Is ethernet controller support with linux possible?
    By Menatep in forum CNC Machine Related Electronics
    Last Post: 04-26-2010, 01:29 AM
