587,372 active members*
3,143 visitors online*
IndustryArena Forum > CAM Software > Mastercam > best roughing path advice
Results 1 to 4 of 4
    Nov 2007
    69
    hi all,
    i'm trying to cut out the parrot beak scollop from a pipe "T", (for want of a better description)
    50mm dia with a 30mm hole thru the guts using a 16mm ball nose end mill
    i can get a surface fin parallel at 90deg for a fin pass
    but i just karnt get a decent roughing pass, what should i be using?
    can start/plunge in the center due to the hole
    file is in X5
    any ideas?
    thanks
    alan
    Attached Files Attached Files
    HAAS TM-2
    Mastercam X4/X5 - Level 3 - Solids @ work / HLE @ home
    Dec 2008
    3124
    There may be a bettr procedure to do this
    - hold horizontal, & just do 2D_Contour cuts to hog out
    - leaves just two Z depth passes to finish with a solid CBD cutter
    ( no ballnose required )
    If you need to be vertical, create a surface from the solid ( leave the hole out ) & extend the surfaces by ( say the tool radius, to get a gentler plunge or 1st pass )
    - this method opens options with using a spiral pass, blend or restmill might be a good start
    Nov 2007
    69
    yes it needs to be vertical, as there are locn pin holes that need to be drilled afterwards
    there is a surface created on the solid supplied (just turn off the solid layer)
    how do i extend the surfaces?
    or do i have to redraw it bigger?
    thanks
    HAAS TM-2
    Dec 2008
    3124
    Quote Originally Posted by riverracer View Post
    Didn't even look at the levels
    to extend an existing surface
    Create --> Surfaces --> extend , select a surface, drag the arrow to the desired boundary, alter distace on user toolbar, Accept
  1. Roughing tool path questions
    By lpmfg in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 12-15-2010, 10:38 PM
  2. Roughing Path for 3-D
    By Grant Nicholson in forum EnRoute
    Last Post: 01-07-2010, 05:09 AM
  3. 3-D roughing
    By mars13 in forum Surfcam
    Last Post: 05-23-2009, 11:38 PM
  4. Tips on Roughing , Please.
    By lostkoss in forum MetalWork Discussion
    Last Post: 10-09-2008, 10:36 PM
  5. Change - from linear path control to CNC path control
    By Fidibus42 in forum CNC Machine Related Electronics
    Last Post: 12-04-2005, 05:43 PM
