587,997 active members*
1,855 visitors online*
Results 1 to 6 of 6
    Aug 2011
    22
    best router bits
    hi all,
    my new cnc machine arrived this week and i'm just setting it up. i will mainly be cutting MDF.
    can anyone recommend the best router bit to buy.
    what is the best i can buy? doesnt really matter about cost. i just want the best.
    any ideas?
    thanks
    zac
    Feb 2012
    Circular saw blades, router bits, tools for router, diamond woodworking cutting tools - CMT
    For cutting MDF a mid range router bit would suffice and top quality is an overkill for just cutting MDF.
    http://www.axminster.co.uk/cmt-route...et-prod808081/
    Aug 2011
    22
    Quote Originally Posted by HorridHenry View Post
    Buy CMT Router Cutter Set from Axminster, fast delivery for the UK
    thanks. do you happen to know which brands are normally considered midrange?
    thanks
    zac
    Feb 2012
    CMT is the mid range. lol
    Now if you want top quality at a price.....
    Workshop & Power Tool Accessories > Router Cutters from Rutlands.co.uk
    Aug 2011
    22
    cool thanks.
    Mar 2003
    35538
    It really depends on your machine and the specific application. Onsrud's 48-700 series are carbide tipped straight bits made specifically for MDF. If you have a machine capable of high cutting speeds, a compression spiral is probably a better choice.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. What router bits to you use?
    By stickben in forum DIY CNC Router Table Machines
    Last Post: 12-23-2008, 06:12 PM
  2. Router bits, End mills v bits
    By bogger44 in forum Commercial CNC Wood Routers
    Last Post: 12-03-2008, 07:06 PM
  3. Using a router for the 1st time. Need advice of cut speeds, router bits etc.
    By Apples in forum DIY CNC Router Table Machines
    Last Post: 09-23-2006, 09:33 PM
  4. Router Bits in OZ
    By Exelanoz in forum Australia, New Zealand Club House
    Last Post: 11-18-2005, 03:41 AM
