Looking for any thoughts on reasonably priced swiss tooling. I've spoken to Kyocera, Genswiss, Iscar on their swiss lines. Back turning tools seem to be the most expensive tool around, $130 for the holder (fine) and $35/insert (2 edges). Otherwise we use mostly simple grooving tools, ISO turning tools, stub drills, etc.
Kennemetal has their line with the two-block system, one block stays in the gang slide as a repeatable back stock, the other holds the insert. The holders with special wedge are like $300+ each and often use proprietary inserts. Makes sense when you're running steel or exotics, but for us the ROI would be minimal.
We run brass on our Citizens so having the absolute best tool life isn't terribly important.
Anyone have a favorite supplier who generally comes in cheapest?
