603,336 active members*
3,934 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Best way to generate code?
Results 1 to 1 of 1
    Aug 2004
    421
    What is the best way to generate g-code for this part? I just want to mill the top face and the pockets. If I select the solid and generate tool path, it appears that it wants to use a ball end mill. Do I have to manually break it down into all the individual pockets and use pocketing?
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. CAD to deckel code
    By dirtpuppy in forum Uncategorised CAM Discussion
    Last Post: 03-08-2005, 08:11 PM
  3. I need sample G code program
    By bunalmis in forum G-Code Programing
    Last Post: 08-24-2004, 09:50 AM
