603,403 active members*
3,621 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Best way to hold thin material for milling
Results 1 to 6 of 6
    Sep 2012
    117
    I am wanting to cut some parts out of 1/8 sheet alum , parts will be about 1.5" x 2.5" with 2 holes in the center. Using a .125 end mill ? ? ? something better ?
    What's the best way to hold the material ? I can cut it in strips and clamp in vise (4"). Or should I use a bigger piece and clamp directly on the table?
    What about something underneath to keep from milling into the table/vise?
    I will be cutting about 100 each time I setup.
    Suggestions ?
    May 2004
    4519
    Best way to hold sheet material is in a punch press.
    I recommend you cut blanks just barely oversize. Hold in vise with step jaws and drill 2 holes. Then use screws to fasten to a fixture plate to mill profile and any other features. Your fixture plate can be as large as you wish it to be. You can even make 2 fixture plates so one can be machining while the other is having parts removed and reloaded.
    Apr 2006
    3206
    Double-sticky tape.
    Wire EDM
    Laser
    Waterjet
    Plasma
    Innovative fixturing that drills all the holes in the plate first, then the plate is dropped onto a second fixture with pins that locate and restrict movement when the part is profiled, separating them from the plate.
    Stacking several plates and doing a group
    Send it to my shop
    Jul 2005
    12177
    Combine elements of all the suggestions so far. Cut the plates to include as many parts as will fit within the limits of your machine. Stack several plates and drill all the holes. Make two fixture plates that the parts can bolt onto and use these to finish all the profiles separating the parts.
    Sep 2012
    117
    After further expermenting , we've decided to go the waterjet route , faster ,cleaner(less finishing) , and most important right now, we don't have the time or machine to deicate to those small parts.
    We prefer to do as much in-house as possible, but the WJ guy can have them done midweek , while we'll still be finishing the setup.
    Dec 2010
    1230
    "cleaner/less finishing" is rarely possible on WJ vs machining. I would likely wj parts that thin but keep in mind all of the edges will be tapered due to wj process. I do a LOT of re machining directly for a wj shop for parts that need flat edges or tolerance that won't allow sanded edges. I The slower they run the less visible taper there will be, there are also 5axis machines that can control taper but that gets expensive FAST. I have production parts thar are 0.25"thick I could have run practically free on a wj but instead of re machining them I stack bar stock. 3 tall, drill through holes over counter bored threads on a fixture, insert screws and cut. It comes out cheaper faster and easier for my part YMMV
  1. holding thin material on lathe
    By 40fordcoupe in forum MetalWork Discussion
    Last Post: 08-24-2011, 04:08 AM
  2. Any way to limit warping on thin material ???
    By flyinwilly in forum Waterjet General Topics
    Last Post: 03-11-2011, 05:02 PM
  3. Hypertherm 1000 thin material bad cut quality
    By Wolfesmetalfab in forum Waterjet General Topics
    Last Post: 04-02-2009, 05:39 PM
  4. Material Hold down 101
    By dneisler in forum MetalWork Discussion
    Last Post: 01-17-2007, 04:15 PM
  5. Material hold
    By gabi68 in forum DIY CNC Router Table Machines
    Last Post: 10-20-2006, 11:52 PM
