Hi all
I've just purchased a BF20L clone (sold under Top Tech brand in aus). Due to the lack of space under the X axis I've narrowed the ballnut type to a square type, either from Rex Machine Industries or Type 2 from Isel. In either case I think I will need a slot about 50mm wide by 2mm - 3mm deep to accommodate the ballnut. This will leave an approx 12mm to 11mm thickness at the bottom of the Tee nut slot. Taking into account this is only a hobby machine (mostly Aluminium and light steel) would this adversely affect the strength of the X table ?
Or has anyone done a retrofit on a BF20 and has any advice ? Just don't want to waste time & $$ reinventing the wheel.
One more question, what is the opinion on direct drive vs pulley drive ?
Cheers
Rob
