587,082 active members*
2,740 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    May 2005
    195
    Biesse Rover 20 NC410
    Has anyone retrofitted a Biesse machine?
    We have a Biesse Rover 20 point to point machine that runs on NC410 programming by biesse. It's a okay program but I'm trying to get all are machines to run off of Bobcad20 and Mach 2.
    Anybody ever change out a system?
    What is possible? What you will!
    Mar 2003
    35538
    Does this have horizontal drilling spindles as well as vertical? ATC? I don't think you can program the drilling spindles with standard Gcode in Mach2/3? I could be wrong, though.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2005
    195
    Yes it does have both vertical and horizontal.
    Mar 2003
    35538
    Are the drilling spindles and router on the same Z-axis? You may be able to use M codes to turn on or drop individual spindles, and use G1 moves to drill. Programming in BobCAD to use the spindles might be tough. rewiring the machine to interface with Mach2/3 would not be an easy job either, I don't think.
    Does the machine work fine right now?
    Gerry
    Sep 2003
    15
    Rover retro
    We just brought a Rover 20 NC 410 on the floor for evaluation and are not sure we are going to retrofit it. However, we run a Thermwood C50 with Galil controller / Camsoft package and One CNC Mill XR for Cam.
    WE recently added an air drill on the Thermwood and drive it as follows ;
    Piggy back of on of our two Z axes, Fired with M codes using offsets to avoid crash between Z head and drill. In our code, the drill is basically a head driven on a common axis ; Router = T1, drill = T3, driven with all standard G codes. It really was rather easy to implement and works great.
    Any tips on the NC 410 would be appreciated ....
    Pierre
    Jun 2010
    Help me! Need electrical diagram of NC410.
    Feb 2008
    482
    i am in the middle of a mach3/ galil conversion. on biesse 335
    its a very big job!
    lots of programming work to do.
    i will be offering a retrofit controller once completed, but it wont be cheap!
    so much to learn, so much to pass on.
    Jun 2010
    battwell, you have control NC410?
    Feb 2008
    482
    yes.(i think)
    what do you need?
    Jun 2010
    I need electrical diagram NC410. Or you can sell me your control NC410?
    Feb 2008
    482
    sorry. i only have rt480 for sale (from my retrofit machine)
    there is a 481 on ebay
    http://cgi.ebay.com/CNI-RT481-CONTRO...item48385da501
    dont think ive seen a 410
    what is not working on your control?
    biesse uk can be very helpful if you spend money!
    Jun 2010
    This shows my screen.
    Feb 2008
    482
    cant tell from that if its a monitor fault or controller fault?
    Jun 2010
    The monitor is replaced. Controller fault.
    Feb 2008
    482
    i am working on a replacement controller for the old obsolete biesse . pc based.
    still lots of software to write but i have it cutting under control etc
    i expect about another month before i have the package ready for sale.
    for the first few i will have to do full instalation myself (approx 2 days)
    it will have the advantage of having mainly standard parts available anywhere. run huge programs. easy to import any drawing etc.
    this is its first ever cut. the gcode took about 5 minutes to produce in total from a drawing.
    [nomedia="http://www.youtube.com/watch?v=tCnrQf9XW5Q&feature=related"]YouTube- biesse conversion first cut[/nomedia]
    shown here running without vac pump on etc while testing/developing
    Jun 2010
    I have a drive axis Yaskawa servopack SGDB-03VDY1. It can be controlled directly Mach3?
  17. #17
    Feb 2008
    482
    not sure.
    only a few yaskawas will take step and direction.
    most are standard analogue. see if its using a +/- 10volt signal. if it is its analogue.
    mine is analogue. i use an expensive motion controller.
    its not an easy retrofit (ive done over a month of programming!)
  18. #18
    Feb 2008
    482
    heres a controller for you!
    [nomedia="http://www.youtube.com/watch?v=3gYzD3Xfsbo&NR=1"]YouTube- Lego CNC 2[/nomedia]
  19. #19
    Jun 2010
    To battwell.
    I like your video on youtube.com. Do you make me a convert to the Biesse Rover 20 NC410 on Mach3?
  20. #20
    Feb 2008
    482
    what is on your machine? how many routers etc?
    do you use drilling ?
    saw?
    my controller works well but wont run the old programs
    wont parametric program fully either.
    but as you see can do anything else
    would need pictures of the inside of your control cabinet to see what boards you have etc
Page 1 of 2 12
  1. Biesse Machine and MeshCam - HELP
    By nem3 in forum Uncategorised CAM Discussion
    Last Post: 05-23-2013, 08:17 PM
  2. Rover CNC machines & ProEngineer
    By Speling in forum CNC Machining Centers
    Last Post: 10-17-2008, 02:36 AM
  3. Mars Rover Finds Life on Mars. Holy cow look at this
    By WallCrawler in forum Community Club House
    Last Post: 01-27-2004, 09:15 PM
