588,130 active members*
5,587 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > biesse rover b - adding tool file problem - error int 53 and int 161
    May 2014
    i have a 10 slot spindle on my machine. i added the tool in the tool setup. then i loaded the tool in the place of a tool i no longer use. when i goto load a program i get the error int 53 and int 161. i cant even get the unload bit program to work. the description says that there is not enough open slots and i need to free up one. but i can not figure out what else to do.
    Aug 2015
    Re: biesse rover b - adding tool file problem - error int 53 and int 161
    hello i have a similar problem, i changed a tool after it was broke but now i get the int 161 error stating " error in tool change parameters preset instructions "
    honestly i dont understand the problem so if you could pleas help me out if you ever got your problem solved? i work on a biesse rover 20 if it helps :/ thanks in advance
  1. Biesse Rover error- Present sensor lacking
    By dbattaglia in forum Biesse
    Last Post: 01-21-2020, 02:44 PM
  2. biesse rover b 4.40 ftk plc 432 error ybn.1.2.6.
    By cutewinuscream in forum Controller & Computer Solutions
    Last Post: 09-04-2019, 07:27 AM
  3. Biesse Rover A3 - PLC error
    By v3rbatim99 in forum CNC Machining Centers
    Last Post: 07-25-2019, 07:24 AM
  4. Biesse model Rover A.3 file conversion to DXF
    By Gabriele in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 09-16-2010, 04:52 PM
