603,310 active members*
2,444 visitors online*
    Jun 2024
    Unhappy BIESSE SELCO EB80 XML IMPORT
    I am manually writing the measurements on the eb 80 model machine. Instead, I want to import an xml file prepared on the PC. I tried a few times but it gives an error. It accepts extensions such as .cpo .ptn .ptx .xml. How can I make my measurements in xml? I exported a list from the machine. I changed the dimensions in the xml content and imported it again. The import process was completed, but the file was output with errors. How can I make a manual XML cutting list for this machine? Can you help me with this?
    Jan 2023
    32
    Re: BIESSE SELCO EB80 XML IMPORT
    Hi, i suppose than your EB80 have the OSI software for cutting ?
    If yes, here some XML generated by an licensed Opticut v6.05g Pro PP (Post-Processor) and it's working perfectly with our Selco SK3 with OSI
    It's for cutting panels with three different dimensions (in millimeters and panel thin = 10 mm)
    3 x 1202 x 402
    4 x 752 x 602
    2 x 602 x 367
    3 files in the zip file:
    BIESSE XML IMPORT V1 (for an machine with an limited cutting levels)
    BIESSE XML IMPORT V2 (for by example an 2022 Selco SK3 with OSI)
    BIESSE IMPORT V3 (NC500) (not an XML but a file with an ".001" as extension, not tested)
    I can provide the Post-Processor file due to copyright, sorry but maybe this file can help you !
    See below for the attachment
    Sorry for my bad english, i'm french !
    Feb 2024
    4
    Do you have the XML import option active? https://disk.yandex.ru/i/27dhjQM9eeQN6Q If not, then OSI can correctly import the xml file created by native Optiplanning. Optiplanning is also able to import an xml file. I can help with the dongle of these programs.
  1. Biesse Selco Post processor
    By miltonsalazar83 in forum WoodWorking Topics
    Last Post: 10-18-2023, 10:10 PM
  2. Replies: 1
    Last Post: 08-02-2017, 07:42 PM
  3. TXT import to Selco OptiPlanning
    By Lauris in forum European Club House
    Last Post: 06-27-2014, 03:21 PM
