Originally Posted by
judleroy
Are you running them with coolant. I have three big Daishowa speeders. Two of them locked up and one continues to run like a champ. The problem is that if you run them without an oil based coolant you are exceeding the bearings maximum speed. The bearings are rated for 17,000 rpm with grease lubricant and 22,000 rpm with oil lubricant. The bearings are not greased in the spindle they are left open for the coolant to keep cool and lubricate. If you run them dry you are messing up big time. Also try not to over speed them because then you exceed the bearing max rpm and they fail. Try to limit speed to around 18000 rpm and always run coolant and see if that helps. Don't ask me how I know what the bearing setup is like inside the spindles. And as for the spindles I have they are not lower speed cheapies. They were over 8000 dollars each. Seems crappie that the bearings can't handle more speed. I would like to see some that use higher rpm bearings that are grease lubricated and sealed so they can be run dry. Good luck.
Judleroy
