Ive been using Solidcam for a while now and not having a lot of luck with just one section.
I have a 4 axis mill and need to out put code for it. (Centroid)
Creating 3 axis G code is fine...creating 3 axis G code and then telling it to repeat around the A axis at set degrees is fine.
If I need to engrave however around the A axis along X I just get the initial code for tool number spindle speed co ordinate system...but the code to run the part is blank.
Any pointers in the right direction would be great.
