603,349 active members*
2,830 visitors online*
Thread: blank screen
Hybrid View
    Apr 2011
    blank screen
    Last night when i went home a milltronics 7200 was just sitting there shut down. This morning I started it up and it has a blank screen, it wont load the os or nothing.I have turned it off and back on it won't even load the floppy disk i have for it.
    Oct 2009
    27
    Check the circuit breakers on the panel. Possibly the CB11.
    Oct 2008
    428
    Do the Front Panel lights come on at power-up but not go out again? If so, the computer isn't booting up.
    As franchcnc suggests, check for 208 - 240 vac at both sides of the disconnect, approx 115 vac between TB1 and TB2, and at the computer power supply output plugs. (As always, be very careful when turning on the power with the door open, there are dangerous voltages in there)
    If you have power at those points, you most likely have a computer problem.
  1. Fanuc 11M Blank Screen
    By samachinetrades in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2010, 05:43 AM
  2. Bridgeport EZ Trak SX blank screen
    By Panther101 in forum Want To Buy...Need help!
    Last Post: 06-04-2008, 09:47 PM
  3. Blank Screen
    By star-turn in forum European Club House
    Last Post: 07-29-2007, 06:54 PM
  4. Fanuc 3M Blank Screen
    By nastek in forum Fanuc
    Last Post: 10-31-2006, 02:56 PM
