587,560 active members*
3,273 visitors online*
    Mar 2006
    92
    Block Numbers
    Is there a radio button or checkbox that will cut the block numbers (N102 for example) on or off. My mill code posts with block numbers, but my lathe doesn't. Is that post processor driven?
    phoodieman
    Jan 2008
    10
    You can turn the sequence numbers on/off in the post. Under the heading General Output Settings look for omitseq and flag that with yes or no (no you get sequence numbers)
    Good Luck
    Mar 2006
    92
    Worked like a charmmmmmmm
    thanx....
    phoodieman
  1. Round Numbers
    By stampman in forum Fanuc
    Last Post: 09-06-2006, 12:12 AM
  2. RFQ - 2 part numbers
    By mcmmach in forum Employment Opportunity
    Last Post: 05-19-2006, 04:18 PM
  3. RS232 program block by block
    By smoregrava in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2005, 07:52 AM
  4. How do I engrave numbers...
    By slp_prlzys in forum DIY CNC Router Table Machines
    Last Post: 10-15-2004, 08:35 PM
