588,147 active members*
5,874 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Bloke - MB3 battery backup?
    Aug 2005
    124
    Bloke,
    Hi. I hope all is well in the UK countryside.
    I've been running the MB3 a bit more now. Its getting back to health. But I realized that the battery backup for the memory must not be working. Can you shed a bit of light on where and how to fix?
    Many thanks.
    Jun 2008
    1104
    The old battery backup was a pack of four cells about "D" size, Nicad and giving about 3.5-4v.
    As long as yours haven't been changed for a different type, they will be easy to pick out in the cabinet.
    Normally, the battery was mounted on the power supply chassis. The positive was connected to TB4-30 and the ground to any 0v.
    Aug 2005
    124
    Thanks.
  1. battery backup
    By Daniel Boone in forum Fadal
    Last Post: 10-03-2012, 06:17 AM
  2. Memory backup battery
    By Captdave in forum Fagor Automation
    Last Post: 07-31-2012, 08:49 PM
  3. MAZAK QT8 BATTERY BACKUP
    By nogginkj in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-24-2009, 11:30 AM
  4. Backup battery replacement
    By nogginkj in forum Fanuc
    Last Post: 10-08-2009, 05:27 AM
  5. MAHO DMU 80t battery backup location
    By suckerdave in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 10-13-2008, 01:09 PM
