587,419 active members*
3,494 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Blowing Fuses with Probotix PBX-2 Breakout Board with Sidestep Drivers
    Apr 2014
    17
    Hello all,
    This is my first machine build so the electronics are new to me.
    The kit I got is from Probotix: 3-Axis SideStep 180 Stepper Motor Driver Kit - 3-Axis SideStep 180 Stepper Motor Driver Kit
    I have been trying to figure out why two of my fuses keep blowing for no apparent reason. The fuses to the Z-Axis and Breakout board are fine but the ones to the X-Axis and Y-Axis blow every time. I have tried about every combination, changing motor wires to different boards, changing grounds, checking voltages, everything; but I cant find a reason. One thing that I just noticed after I got home is that my VREF was low at 1.6V rather than 3.2V for a 2A rating for the motor, but it doesn't seem like that should matter. I have talked to a guy at Probotix and he couldn't seem to see a problem with my wiring and had never heard of this problem before. I'm using the suggested 2.5A 250V fuses. Just hoping you guys can help me figure out my problem.
    Although the Z seems to be alright I am yet to get it to move with the computer, Im not sure if its because I got a parallel port extension cord which might mess up the pin configuration?or if its a bigger problem.
    The only thing Ive gotten to work so far are the limit switches and I had to use a different pin configuration than suggested to get them to work.
    I attached some pictures showing my setup.
    Thanks!
    Feb 2007
    4553
    Re: Blowing Fuses with Probotix PBX-2 Breakout Board with Sidestep Drivers
    Quote Originally Posted by CSpurge View Post
    Hello all,
    Thanks!
    What happened to the pictures?
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2014
    17
    I didn't even think this posted, my screen just kept going white after hitting submit. Ill add the pictures now.
  1. Single TB6560 Drivers+Breakout board?
    By Zeppelin1007 in forum Stepper Motors / Drives
    Last Post: 04-22-2016, 07:42 AM
  2. Fried Probotix Breakout board or drivers?
    By pippin88 in forum Stepper Motors / Drives
    Last Post: 09-25-2012, 11:13 AM
  3. Fried Probotix Breakout board or drivers?
    By pippin88 in forum DIY CNC Router Table Machines
    Last Post: 09-10-2012, 01:34 AM
  4. Probotix SideStep Chopper Driver
    By jzurek in forum DIY CNC Router Table Machines
    Last Post: 03-17-2011, 04:03 PM
  5. PROBOTIX PBX-RF Breakout Board problems
    By artwood_decor in forum Stepper Motors / Drives
    Last Post: 04-15-2008, 09:47 PM
