588,130 active members*
5,022 visitors online*
Results 1 to 13 of 13
    Sep 2004
    222
    Bobart pro X?
    Anyone using Bobart pro X? Do you need V20 to run? I am looking for something to import line artwork.
    Jun 2003
    446
    BobART PRO-X allows you to import Jpeg, Bitmap, Gif, Tiff and png files into it. Once the image is there you can use Raster to Vector operations to get all of the 2D contours. Then you send those 2D contours to V20 and machine them. What program are you creating your line art in? For example, Corel will allow you to create and export a dxf file. That DXF file can be opened in V20. I do this from time to time. BobART PRO-X only works with V20. The primary upgrade to BobART PRO-X is embossing and relief modeling and toolpathing.
    CNC Dude
    Sep 2004
    222
    I have V18 and V19 now and don't want to upgrade. I have a drawing done by hand and scanned in but need to convert it so I can use it.
    Jun 2003
    446
    Would you like me to see what I can do with it for you?
    CNC Dude
    Sep 2004
    222
    I have a scanned drawing and would like to see how this works so if you would like to convert it to a dxf here it is. if this works let me know how it was done. Thanks
    Attached Thumbnails Attached Thumbnails engraving angle speaks with women.jpg
    Apr 2003
    372
    Fastolds,
    I am using Bobart Pro X, it rocks. Yes you do need V20. The image you attached, do you want to do a relief toolpath or a simple engraving of it?
    Let us know and I too will see what I can do for you.
    Dave
    "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
    Greetings From Down Under
    Dave Drain
    Akela Australia Pty. Ltd.
    Sep 2004
    222
    Just a simple centerline engraving. I get these types of images from time to time and would like to be able to do different things with them. Scale them up or down, edit them, etc.
    Sep 2004
    222
    Any Luck???
    Apr 2003
    372
    I have had a go at it. The biggest problem is that in BobART you can not achieve a centre line vector it will only do an outline, I believe they are working on this. Try the demo version of wintopo (I think this is what its called) it will do a centre line vectorization.
    Good Luck
    Dave Drain
    Jun 2003
    446
    BobART PRO-X outputs 2D contours from a picture that represent the center of the cutting tool unless otherwise specified. Such as in a pocketing cycle. I had a go with the picture and everything worked well. I then used the 2D contours to build a relief model. You can scale, edit and use the settings to get the required result.
    CNC Dude
    Jun 2003
    446
    And then there was toolpath...
    Jun 2003
    446
    And then there was G-Code and Simulation...
    Jun 2003
    446
    Or you can just engrave the design and produce the NC program. I hope these posts shed some light in terms of what BobART PRO-X can do for you.
    CNC Dude
