603,310 active members*
2,492 visitors online*
    Mar 2008
    21
    Bobcad 21 post processor
    I have bobcad 21 and I have a lathe with fanuc oi-tc control. My cd with post processors no longer works. I have been using a post processor for fanuc 18 it and I can get it to work but it does some things that are kind of unhandy. For 1 thing it tries to post in radius rather dia. if I dont click on the Y=Y*2 under envirorment. Another thing is unless I click on no numbers it outputs strange things when posting a code for a G71 cycle. If I click on no numbers it works ok but I have to do this every time I open bobcad. Another thing is it leaves out "G00" on the first line of code after a G71 and the machine wont run like this unless I manually insert a G00 after the G71 cycles.
    Aug 2009
    1573
    Re: Bobcad 21 post processor
    ...do you have an app File named "LatheEditPost" look in BobCad21 folder. If not, you can try using the attached program from BC23 that I have might work for ya.
    DJ
  1. Replies: 0
    Last Post: 07-07-2017, 12:56 PM
  2. BobCAD Post Processor
    By Poseidon in forum BobCad-Cam
    Last Post: 05-03-2015, 06:30 AM
  3. BobCad Post Processor
    By 1QWK96GT in forum BobCad-Cam
    Last Post: 03-24-2011, 09:48 PM
  4. with bobcad v23 post processor
    By cncpilot in forum Fadal
    Last Post: 05-20-2010, 11:24 PM
  5. Bobcad as a post-processor?
    By parkerbender in forum BobCad-Cam
    Last Post: 03-27-2010, 10:47 AM
