603,900 active members*
2,945 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad with Anilam Crusader II
    Jan 2006
    7
    I have a Anilam Crusader II control and I am trying to get it to comunicate with my pc based BobCad V18 software and it is not working if you have any suggestions let me know [email protected]
    Aug 2004
    18
    Crusader II RS-232
    first you need to make sure your RS-232 works. You need to do a loopback test. on the DB-25 connector on the back of your cabinet you need to make a jumper plug to connect pin 2 to pin 3 and then on a seperate wire pin 6 to pin 20. push the manual key, pull out the estop, press aux key and 2740,push the start button. if this passes the test it will say 0 in your upper display. if not there will be an error 38 or 39.
