603,930 active members*
4,118 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad v23 problem with the selection of the center of a solid circle
    Jul 2003
    148
    Hi, I'm having one issue with bobcad that I've not ye been able to figure out. I import a IGES file into the software. I have it come in as a solid. Ten when I click on the solid cylinder with find center of circle selected to move the part to orgin or X,Y, Z zero. The part moves but used the click point as the base of movement. I've read the help file and been watching the video's but figure that its something super simple I'm over looking. I have gone into the selection option screen and made sure all the option are selected. Then I went in and even turned some of them off. What am I doing wrong????? Thanks.
    Jul 2009
    219
    You will probably have better luck if you extract the edge of the circle, then place a point on the arc center. Now use the point to translate it to wherever you want.
    Oct 2006
    173
    You will need to extract the 2d edg,e and then use the shift select to display the snap point while translating.
    Look at the edge extraction done in this video..
    [nomedia="http://www.youtube.com/watch?v=Wl1yRusgDdY"]‪How to machine 2d cuts off a solid model using BobCAD V23‬‏ - YouTube[/nomedia]
    And use the
  1. BobCad Solid JPG
    By cncpilot in forum BobCad-Cam
    Last Post: 04-09-2011, 09:32 AM
  2. Find center of circle
    By dano9700 in forum Engraving Machines
    Last Post: 12-16-2010, 02:19 AM
  3. find center point of circle
    By Farzaneh_2010 in forum G-Code Programing
    Last Post: 10-10-2010, 08:34 AM
  4. BobCad Solid
    By glbreil in forum BobCad-Cam
    Last Post: 05-24-2007, 12:04 AM
  5. Find the center of a circle
    By Hobbiest in forum WoodWorking Topics
    Last Post: 01-28-2004, 06:24 AM
