603,945 active members*
3,550 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > BobCad V26 setup sheets not correct
Results 1 to 8 of 8
    Jun 2012
    514
    Checking my set up sheets and the stock dimensions are waaaaaay off for a imported file from V25. Is this a bug? How do I correct this? Anyone else have this going on?
    Big Chipin, spreading tha cheese, I be Big Chipin for days!
    Mar 2012
    1570
    So you are going from V25 ( all ready setup part ) to V26 and create a setup sheet where the stock dimensions are off?
    Al DePoalo
    Partner Product Manager BobCAD CAM, Inc. 866-408-3226 X147
    Jun 2012
    514
    yes....i just imported the v25 file and run a set up sheet to see what it looked like and it was off.
    So are you saying i have to reset stock dimensions on every part i bring from v25 to v26 for the set up sheet to work correct?
    Oct 2004
    832
    I have found a lot of files done in V25 dont work out right in V26, toolpaths especially can be weird, just run it through again and all is fine.
    Hood
    Jun 2012
    514
    oh...no....i am just testing out the waters in demo version...I had a member contact me about selling me their v26 but I cant go backwards and have to redo toolpaths ect ect in all these files.... SMH!
    Mar 2012
    1570
    Hood are you reporting the issues?
    Oct 2004
    832
    Big Chips,
    you dont actually have to redo the toolpaths as such, just walk through the strategy if it is incorrect and choose the correct options. It doesnt happen with all of them but a few I tried it did.
    Al
    No I didnt report that as I didnt really think there was anything wrong as old files going into new version with different options I would expect some incompatibility.
    Hood
    Jun 2008
    1838
    Big Chips
    Odd issue for sure, it intriqued me so I have checked a few of my old V25 files in V26, done some with "bounding box", "wireframe" and "solid" stocks, all came through the setup sheet I used (I only tried the "Full Setup Sheet" option) fine here, if you are using a different option then there may be some difference
    Only big issue I have had so far with V26 is the complete loss of a couple of files, when I say loss I don`t mean the files have disappeared off the PC, what I have is the loss of the content of the file, example, worked a lot of hours on a 3D mould file, came out at a little over 82Mb, I made sure it was saved properly and was indeed that size, then went back onto working machines, couple hours later I went to open the file I saved, came up empty ! ! ! Nothing at all, even though it still showed a file size of 364K so there should have been something there
    Very, very annoying, I can put up with losing work I have done due to me not saving out often enough on large(ish) files when it "falls over" but this is just a real PITA
    Also had a few of my older V25 files (Not the last build ones) that I can`t open now, they were done in a fully licensed copy of V25 but I get a can`t open file because it was done in Demo version error message, luckily they were not of any great importance so not worth reporting as a "bug" for now, if it gets any worse then I will make a report.
    Regards
    Rob
    :rainfro: :rainfro: :rainfro:
  1. setup sheets
    By famous08 in forum Mastercam
    Last Post: 05-17-2013, 03:01 PM
  2. Better Setup Sheets?
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 11-01-2011, 05:19 PM
  3. X2 AND X3 SETUP SHEETS
    By CNC_BOB in forum Mastercam
    Last Post: 03-06-2010, 02:42 AM
  4. X4 Setup sheets
    By 72k5 in forum Mastercam
    Last Post: 03-04-2010, 07:55 PM
  5. Setup sheets
    By laka in forum Uncategorised CAM Discussion
    Last Post: 09-18-2008, 07:10 PM
