Hi, another possibility is to inset long I or h section beams across the floor....actually under the floor boarding in the attic and perch them on the outer walls.
If as you say there is a central load bearing wall, then this would support the centre of the beams.......could be done?
It would be relatively easy....not dead easy..... to stick a couple of steel beams through the outer walls from the outside if you have clearance between your house and the neighbours.
Even a single steel beam would make a huge difference.........getting it up there and in place is another story.......but a possibility not to be ruled out.
Ian.
