603,896 active members*
6,242 visitors online*
Thread: boot problem
    Jun 2004
    16
    boot problem
    Hi everybody,
    I have a problem with Fanuc 11M control: I cannot start PLC. Inside the cabinet on the PLC board, there's a digital display (about 2.5x2.5 mm ), that display only a digital "8". Usually, the display countdowns from 8 to 1 or 0. But now the boot sequence remains on "8" and on the CNC monitor I've got only flashing small dots.
    Can somebody please help me to identify the problem of the PLC?
    I would check the power supply if it is noisey it will cause this alarm
    Jun 2004
    16
    Thank you. Indeed, I have to replace the power unit.
  1. Mori MSG 501 (FS 18i-MA) BOOT UP PROBLEM
    By L. Sakthivel in forum Fanuc
    Last Post: 08-18-2019, 10:31 AM
  2. Crusader series M will not boot up pots problem?
    By RGMJOE in forum DNC Problems and Solutions
    Last Post: 01-12-2013, 01:37 AM
  3. Moriseiki SH403 Boot up problem
    By L. Sakthivel in forum Mori Seiki lathes
    Last Post: 12-20-2007, 06:31 PM
  4. MB1 won't boot
    By daveelc in forum HURCO
    Last Post: 04-20-2007, 02:32 AM
  5. multi-boot two HDs
    By Karl_T in forum Computers / Desktops / Networking
    Last Post: 06-21-2005, 05:58 AM
