Well, I was turning down some aluminum to make a index pulse disc for the mill and ruined a part trying to get cute with the boring bar.. My Lathe/mill combo G9729 harbor freight model still has the rotating tool post which I like and hate all at the same time.
It's great for OD turning bit has a strange height for my boring bars. Even with them shimmed as high as they can go they were needing to be rotated to clear the underside of the boring bar. So while sneaking up on the final ID of my part I usually try to make a final cut of around .020" or else the boring bar chatters like hell and leaves a terrible finish. The problem is because the bar requires being rotated down and off center its kind of guess work because the dials no longer coincide with the actual cut depth. So I went over and the fit was too loose so needed to start all over..
So I decided I was going to fix the problem so I could use the wheel markings as intended. After looking at it for a few minutes is decided to flip the boring bar over in the tool post with the cutting edge down and pointed at the backside of the Lathe. This allowed me to get the cutting point at the center height of the spindle axis. I decided to put a dial indicator on the d axis to ensure I was accurate this time. So I made a test cut to see where the minimum depth of cut the Lathe would be happiest at and low and behold it cut smoother with an unbelievable surface finish.. Zero chatter, and I was able to cut from .001" to .100" with no chatter and great smooth cutting and perfect finish..
So the part came out Gorgeous!!! And I learned something new. I also decided to try my parting tool which I never could get to work very well and boom!!! Cuts like a hot knife through butter!!
So for anyone plagued with chatter. Flip the tools upside down and welcome the new amazing fun the Lathe becomes!!!
Hope this helps some of you out! I know my build will now incorporated more of a slant bed design with rear mounted tool post to flip all tools upside down. I imagine a more rigid machine can handle heavier cuts without chatter. But these smaller machines struggle with it. I'm so excited to find a solution I had to share!
Happy chip making!!
Chris
Sent from my XT1080 using Tapatalk
