603,969 active members*
3,119 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Boring a Pocket in Lathe with Boring Bar Help
    Jan 2009
    245
    I have a part That is attached. But basicly what I want to do is This part is 2.5 OD with a 1.125 ID. It is about 2 inches long. The 1.25 ID goes for about 1/2 deep then it opens up to roughly 1.6 at a 45 degree angle then goes back down to 1.25 ID after about an inch. So it is a Cave type geometry. I have a Boring bar from Kennametal that is a A12-NER2 with a NG2125LK insert. Basicly all this is, is a .125" WIde square insert in a Right Hand Boring Bar, No radius on either corner. I want to use this bar for the cave like toolpath. The problem is that there is no bar in any of the librarys in my MASTERCAM X. I try to draw a tool but have not had any good luck. Does anyone have any ideas I can try? Thanks.
    Attached Files Attached Files
    May 2004
    4519
    Just use a groove tool and set width to 0.125" and radius to 0.000". Are you sure you are using the filters correctly when selecting a tool?
    Sep 2008
    34
    As TXCNCMAN said, take a look at your tool filtering, that insert it's well defined on the default library Lathe_Inch.LIC.
    Right click on your toolpath parameters page, on the side of any of the tools listed and click on "Create New Tool".
    Then Follow the Screen shots attached.
    HTH
  1. Indexable boring bar in boring head?
    By Molochnik in forum MetalWork Discussion
    Last Post: 04-15-2010, 01:36 PM
  2. Boring bars on a lathe
    By littlerob in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2009, 04:13 AM
  3. Pocket vs Boring?
    By THend in forum Uncategorised CAM Discussion
    Last Post: 11-07-2008, 08:21 PM
  4. Lathe Boring Titanium?
    By Otokoyama in forum MetalWork Discussion
    Last Post: 02-06-2006, 03:22 AM
