603,861 active members*
3,897 visitors online*
    Dec 2005
    30
    Angry Boss 6 Axis Problem
    Please Help !!
    Slight problem with Boss 6. I switched it on this morning and in setup mode
    both the X and Y axis move then stop, when stopped there is a buzzing noise. I can stop the buzzing noise by switching the function switch across to restart. Then the axis move again, but stop as soon as I take my finger off the switch, and the buzzing starts again. During this time the Z axis is not moving at all. I have checked all the transistors on the Z and they are OK.
    Any Ideas ??
    Dave
    Sep 2003
    552
    These are stepper machines so if a axis moves it is getting pulses in a quadrature fashion. I would suggest checking your computer power supply. DC voltage and AC ripple. If all is OK there I would check and reseat the boards.
    Good luck,
    Darek
    Dec 2005
    30
    Thank's Darek,
    Can I find the thing's you suggest in the maintenance manual.
    Dave
  1. Boss 6 Z-Axis Pulley Identification / Problem
    By snakebit95 in forum Bridgeport / Hardinge Mills
    Last Post: 09-04-2006, 09:25 PM
  2. Boss 9 z axis problem
    By Drewboy in forum Bridgeport / Hardinge Mills
    Last Post: 03-29-2006, 02:53 AM
  3. Series 2 BOSS 6 Axis motion problem
    By craig96us in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2006, 06:06 PM
  4. Boss 5 Y axis problem?
    By jeaBOSS5 in forum Bridgeport / Hardinge Mills
    Last Post: 12-11-2005, 10:40 PM
  5. How To; troubleshoot an Axis problem on Bridgeport BOSS
    By inthedark in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2004, 02:35 PM
