587,593 active members*
4,092 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > [B]Program upload problem with fanuc 6T[/B]
Results 1 to 9 of 9
    Feb 2010
    Hi all,
    I try to enter a short program under Edit mode and all things is ok .When I change the mode to Memory mode to run the program .I can not find it where I entered the right program no. without any alarm.
    while when I entered not exist program no it give me alarm no.071 "the address to be search was no found".
    sami
    Mar 2003
    2932
    To input a program by keys:
    EDIT mode.
    PRGRM
    O0001 INSRT (creates program O0001)
    Key in each block followed by INSRT.
    To search for program:
    EDIT or MEMORY mode.
    PRGRM
    O0001 and cursor down
    To see a list of all programs in memory (Memory Arrangement):
    EDIT mode.
    PRGRM
    CAN
    ORIGIN
    Feb 2010
    run a program in memory
    hi dcoupar,
    How can I run a program in memory?
    thanks
    Mar 2003
    2932
    1. Select the program you want to run:
    MEMORY mode
    Key in O0001 or whatever O number you want to run
    Press the cursor down key
    2. Press CYCLE START
    Feb 2010
    hi
    I try to enter a short program under Edit mode and all things is ok .When I change the mode to Memory mode to run the program .I can not find it,
    Does this sound a memory problem?
    Mar 2003
    2932
    In EDIT mode, type O then press cursor down. Does the program on the screen change to the next program in memory? Keep doing this... it should change programs every time.
    Feb 2010
    The problem is there is no programs in memory else one I entered before under edit mode?
    also I note the BMU switch on master board was on then I change it to off state and I am not sure the purpose of this switch but I read before that change the state of this switch may cause damge to memory?
    thanks
    Mar 2003
    2932
    I've never seen the BMU switch you mentioned. It would seem that this would be short for Bubble Memory Unit, but I could be wrong. Why did you turn it off?
    Feb 2010
    I turned it off because I read before in some froums:"DO NOT TOUCH the toggle switch on the main PCB marked "BUBBLE FREE MODE". It can damage your bubble memory board unless you really know what you're doing"
    and I see in some pictures that standard position is in the off state .
    if you have any idea please let me know!!
    thanks
  1. Help with Fanuc OM DNC upload
    By darrylh in forum Fanuc
    Last Post: 12-05-2011, 08:57 PM
  2. Fanuc 11M DNC / upload
    By whweapons in forum Fanuc
    Last Post: 01-12-2010, 06:27 AM
  3. Mitsui 618 CNC FANUC program problem
    By HamerHead in forum Fanuc
    Last Post: 02-03-2009, 06:48 AM
  4. Program Memory problem in FANUC 0i Mate MC
    By ranjankrana in forum Fanuc
    Last Post: 01-10-2008, 10:34 AM
  5. Fanuc 6 M SW upload.
    By chinthakahk in forum Fanuc
    Last Post: 09-28-2007, 12:59 AM
