hello all,
i have a question about braking resistors. the fanuc drives i am retrofitting have a braking resistor of 10 ohms.this is in series with a adjustable overload relay. the motors are gettys type 10. i havent found the specs on the armature resistance. the fanuc drives are 30 amp,170volt dc.
i am using the 2020 rutex. should i stay with the current braking resistor, and leave the overload relay in the circuit? will the overload relay provide protection of the back emf if set below the 40 amp max of the drive?
