588,167 active members*
4,612 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > Brand New X700 Laser Engraver 500 x 700mm
Results 1 to 1 of 1
    cnc_laser Guest
    Standard specification:
    Control system: DSP
    Working size: 20"x28"(500mm x 700mm) with double side open door
    Up and down work plate: 6" (160mm)
    Laser tube type: Co2 Glass sealed laser tube
    Laser power: 50W
    Driver type: Micro Stepping Motor
    Max speed: 1000mm/s
    Resolution: 1000 DPI
    Location precision: 0.01mm
    PC Interface: USB2.0 and USB Disk
    Software: Lasermate 5.02
    Image form: HPGL, BMP, GIF, JPG, JPEG, DXF, DST, AI
    Warranty: 12 Months (3 months for Laser tube and mirrors)
    Machine Dimension(L/W/H): 1150*860*970(mm)
    Package Dimension(L/W/H): 1700* 1000*1200 (mm)
    Package: Standard Wooden case for export
    N.W. : 125KG
    G.W. : 185KG
    Standard accessories:
    Laser Engraving software Package (English Version)
    User Manual (CD)
    CW-3000 chiller
    Air exhaust fan
    Air Pump
    Communication cable
    3 Reflect optics (installed in the machine)
    1 Focus optics (installed in the machine)
    1 Laser tube
    Other tools
    Optional accessories:
    Honeycomb (for soft materials engraving and cutting)
    Reddot Positioning Function (showing outline or laser dot position)
    Rotary(for engraving cylinder materials)
    Upgrade to 60W
    More details please go to the following website:
  1. My X700 is Doing laser And Axis Problem
    By m.raheel in forum Redsail Laser
    Last Post: 03-22-2016, 04:22 AM
  2. High Quality Laser Engraver 500 x 700mm
    By cnc_laser in forum News Announcements
    Last Post: 07-04-2013, 10:20 AM
  3. Replies: 2
    Last Post: 05-21-2013, 05:52 PM
  4. x700 redsail laser cutter
    By Mannetjie Both in forum Redsail Laser
    Last Post: 03-11-2013, 05:50 PM
  5. New Laser X700 help!
    By harrison1 in forum Redsail Laser
    Last Post: 05-23-2011, 08:22 AM
