587,524 active members*
3,357 visitors online*
Results 1 to 4 of 4
    Breakout board isolation
    I have a 5 axis breakout board and am not sure how is the USB power supply isolated from the main board and from LPT port. Do not see any chopper on the board. The situation refers to a 230V USB power adapter too. Maybe using the USB from the PC is a better solution vs an external power supply.
    Did anybody dive into this subject?
    Cazare Pensiunea La Trovanti Horezu
    Sep 2013
    6
    Re: Breakout board isolation
    What kind of breakout board do you have? Is it home made? Can you post a model number or some pictures. I'm sure we can figure this out. Just post as much information as you can.
    May 2005
    1397
    I don't like isolation. It's more trouble than it's worth and even with the best, it's still possible to fry your PC if you do something dumb. And I can do dumb things. I use an old "throwaway" PC to drive the CNC machine and keep my nice iron for design only.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Nov 2008
    110
    If you think isolation more trouble than it's worth then you were extremely lucky till now. Fried PC is one possible outcome, other possibility are frustrating "quirks" that such system may have. Random crashes, missing or additional steps or e-stops and so on. I worked on such system and there were days when I was just a tiny, tiny bit from throwing the damn thing out of the window. Ground loop is bad for mental health
  1. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
  2. Usefulness of the Opto-Isolation in Breakout Board
    By leaveme in forum DIY CNC Router Table Machines
    Last Post: 09-22-2010, 07:47 PM
  3. pic´s are able to be considered some kind of pc-board isolation?
    By patriciooholegu in forum PIC Programing / Design
    Last Post: 11-27-2009, 04:32 PM
  4. Lost in space - Isolation Board??
    By CPierce18 in forum DIY CNC Router Table Machines
    Last Post: 08-11-2007, 06:13 PM
  5. PCB Trace Isolation - Minimum Track and Isolation
    By ahoodlum in forum CNC Machine Related Electronics
    Last Post: 09-26-2006, 05:02 AM
