588,197 active members*
4,945 visitors online*
IndustryArena Forum > CNC Electronics > Viper Servo drives > Bridgeport Boss servo machine retrofit
Results 1 to 5 of 5
    Jan 2006
    204
    Larken,
    I have a Bridgeport boss R2E4 servo machine that has a dead control and I am in the process of doing a retrofit. I would like to use the Viper 200 card. I was wondering about the power supply.. and Heatsinking
    the servo's on my machine are as follows:
    powertron
    permanent Magnet DC servo motor
    Rated Torque: 30" pounds
    Max Voltage: 146
    Rms Amps: 14.6
    Max pulse Amps: 58.3
    Frame C402-3
    Model 402CNSPOS72
    Serial 15347
    With a BEI encoder Mounted
    Model 25G-250-ABZC-8803-sM18-s (150336-250)
    Part Number 924-01029-092A
    Date 11-1-84
    archie =) =) =)
    Jan 2006
    49
    Hey Jeep534:
    I’m in the process of doing a similar retrofit. Using the Viper 200’s and I just went to http://toroid-transformer.com./ and emailed them my motor spec’s and they were very helpful. You might want to give them a try.
    Jay
    Feb 2007
    969
    Yes, that motor is ok for the Viper 200.
    For heatsinking, mount them on the edge or flat on 1/4 alum plate and have a fan blowing on them. At the higher voltages some of the power resistors for the voltage regulator need abit more cooling.
    To get 146 volts DC, your transformer should output about 100 volts.
    Jan 2006
    204
    Jay,
    I sent you a pm. It might be nice to share our misery as I just started gutting the cabinetts this evening.
    Happy Hunting
    archie =) =) =)
    Quote Originally Posted by sandefuj View Post
    Hey Jeep534:
    Jay
    Jan 2006
    204
    I have updated the photo's on my web site http://jeep534.smugmug.com/Hobbies
    the next step is the electronics. I am working out of town so progress is slow
    Happy Hunting
    archie =) =) =)
  1. MY Bridgeport Boss 5 & AJAX retrofit
    By will_b in forum Centroid CNC Control Products
    Last Post: 09-10-2012, 11:40 PM
  2. Bridgeport boss 6 retrofit
    By dandonegan in forum Gecko Drives
    Last Post: 12-18-2011, 05:39 PM
  3. Bridgeport boss retrofit
    By cat37 in forum Bridgeport / Hardinge Mills
    Last Post: 08-22-2007, 02:46 AM
  4. CamSoft Bridgeport Boss 4 retrofit
    By kz1000 in forum CamSoft Products
    Last Post: 06-14-2007, 11:22 AM
  5. Bridgeport Boss Retrofit help
    By moto21 in forum Bridgeport / Hardinge Mills
    Last Post: 06-10-2005, 04:32 AM
