588,150 active members*
5,420 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport Coolant enclosure (Poor Man’s Shower Curtain)
Results 1 to 6 of 6
    Mar 2007
    39
    Here are a few photos of my “coolant containment project” completed. I’ve also added a garden hose to spray off the pallets and work area like they have mounted on another brand of CNC mill. Any comments or suggestions are welcome. Happy carving.
    Oct 2006
    735
    well your floor is cleaner then mine hehehe
    b.
    Jan 2007
    129
    wow what a neat idea! Seems like I'll some construction to do once my V2 is up and running. What did you use for the "curtain" lexan? Plexi?
    9 1/2
    B.C.I.T. Machinist CNC
    Mar 2007
    39
    Quote Originally Posted by 9 1/2 View Post
    I used stainless sheet metal for the “Tub” and bolted the 3/16” thick Plexiglas sheets to it. I used lots of clear silicone at the joints and a closet slided and wheels from Home Depot for the front door.
    Jan 2007
    129
    Thanks for the info. I've long had issue with chips flying around the garage. My other passion is motorcyles and motor building, obviously they don't appreciate the intrusion of chips.
    peace
    Owen
    9 1/2
    Mar 2007
    39
    peace
    Owen
    Hi Owen,
    I was thinking of suspending four walls of clear plastic sheeting around the CNC machines and adding a “roof” to air condition the area during the summer months when it get to be 114° outside. Maybe you could utilize the same idea for a sort of “clean room” for your motor assembly area!
  1. Quick and Dirty X3 Coolant enclosure..cheap too!
    By KOS in forum Benchtop Machines
    Last Post: 12-02-2007, 07:27 PM
  2. My poor X1...
    By darkith in forum Benchtop Machines
    Last Post: 08-06-2007, 02:56 PM
  3. Bridgeport CNC Knee Mill Enclosure
    By Jadaan27 in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2006, 04:28 AM
  4. Bridgeport TC-2G Coolant Motor Overload
    By PPM in forum Bridgeport / Hardinge Mills
    Last Post: 09-26-2005, 07:45 PM
  5. Poor results, help please!
    By Swede in forum Hard / High Speed Machining
    Last Post: 04-04-2004, 05:23 AM
