587,143 active members*
5,462 visitors online*
    Jul 2008
    5
    bridgeport eztrak dx read out
    All seems normal on start up, until I go to home the system, readouts go from zero to really big numbers (54136250000) always on the x and y sometimes on z.
    This all happens as soon as I start the home.
    The table will move to the end of its travel, sometimes I can jog it back other times when I try to jog it back it wont stop.
    I have tried to reboot doesn't seem to go through the reboot disc, it does respond to the ez trak system disc.
    Apr 2013
    40
    Re: bridgeport eztrak dx read out
    Are these using scales or encoders? I would guess the scale/encoder is going bad, a bad breakout board, or possibly you have some huge amount of error compensation on. Is the BMDC board mounted securely?
    Jon
    H&W Machine Repair
    Nov 2004
    3028
    When it boots, before homing, press *, a box should open asking for a code. type in 11235 followed by enter twice. Machine parameters should come up. if a series 1, they should be 30 for X, 12 for Y, make offset 0 for both, backlash and pitch error should never be greater than .0035 inches. Start there.
  1. Bridgeport EzTrak II SX software
    By thechatroom in forum Bridgeport / Hardinge Mills
    Last Post: 11-09-2012, 09:41 PM
  2. Bridgeport eztrak bmdc
    By dreammstr6 in forum Bridgeport / Hardinge Mills
    Last Post: 08-12-2010, 09:10 PM
  3. Bridgeport eztrak dx 2
    By markjab in forum Bridgeport / Hardinge Mills
    Last Post: 06-18-2009, 10:09 PM
  4. BRIDGEPORT WITH EZTRAK DX
    By cruizer67 in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2009, 02:15 PM
  5. bridgeport EZtrak SX
    By pedro.ledezma in forum Bridgeport / Hardinge Mills
    Last Post: 04-20-2008, 05:07 AM
