587,850 active members*
3,507 visitors online*
    Jan 2006
    25
    Bridgeport Interact 308 problem
    I've been having problem with my machine dropping tool during tool changes. the program will call out an M06 and the spindle will unclamp the tool before it homes to the tool changer height. I was wondering if anybody had dealt with this problem before or might have an idea what is causing it to happen.
    Patrick
    Nov 2004
    3028
    The switch indicating to the control that the tool changer is forward is what triggers the tool release. Maybe this switch is bad. Otherwise, I would be reloading the software.
    George
  1. Bridgeport Interact 1 Mk II - Ktk Drive Problem
    By palikalsi in forum Bridgeport / Hardinge Mills
    Last Post: 03-23-2015, 12:50 PM
  2. Bridgeport Interact 24v DC reg problem
    By Paul_Leoni in forum Bridgeport / Hardinge Mills
    Last Post: 02-23-2013, 09:44 AM
  3. Bridgeport Interact 2 Series 2 Problem
    By theo1 in forum Bridgeport / Hardinge Mills
    Last Post: 06-05-2011, 12:53 PM
  4. Bridgeport Interact 720 memory problem!
    By FLjoyride in forum Bridgeport / Hardinge Mills
    Last Post: 10-29-2010, 01:35 AM
  5. Bridgeport Interact 1 MkII problem
    By sparsrus in forum Bridgeport / Hardinge Mills
    Last Post: 05-02-2006, 09:53 PM
