588,316 active members*
5,220 visitors online*
Results 1 to 5 of 5
    Nov 2009
    20
    Bridgeport Interact series 1 questions
    Hi All,
    I am new to this forum, Hope you might be able to help.
    I Have just purchased a Interact series 1 with 151 controll, And have a few questions as I am new to this machine and controll.
    The coolant pump doesnt seem to work, there is a lot of sludge in the bottom of the tank which could be jamming the pump, maybe blown a fuse or tripped out. Do you have to have the tank filled with coolant? and do you have to turn the pump on with a M command as well as the drip ,flood switch.
    I also would like to link up my computer to the 151 control how do I do this?
    Thanks for any help.
    John
    Jan 2005
    1121
    re
    clean the gunk
    fill coolant
    spindle on, coolant switch on turns on coolant
    search archives for heidenhain comm issues, most issues are the cable is fussy
    Nov 2009
    20
    Thanks Gus,
    One other problem is the y axis judders,when I turn the machine on, It smoothes out if I move the Y forward and backwards but if I leave it for a while it judders again.
    I believe this is a problem caused by coolant and oil getting into the motor.
    Can anyone give me instruction how to remove motor dissamble and clean?
    John
    Oct 2008
    44
    Quote Originally Posted by irishjam View Post
    Thanks Gus,
    John
    swap servos or motors to confirm the problem before you disassembled the motor. it may also cause by a servo fault.
    Jan 2005
    1121
    basically remove the pulley, remove the 4 bolts that hold the servo to the case and slide the servo out. Couple of methods that hold the pulley on, one of mine was friction with tapered bushings, built in holes to help back it out. Encoder and tach come off of the back, a couple of long bolts hold the case together. Don't drop it, magnets break and you are screwed.
    Slow speed error I think I would suspect tach brushes.
    I did have a leaky one in the same spot that would collect coolant and need cleaning once a year, but it would error at speed
    I dropped that one and had to buy new, that fixed the problem tho....
    check brushes before taking it all apart
  1. bridgeport series 2 interact 4
    By dcchip in forum Bridgeport / Hardinge Mills
    Last Post: 11-15-2010, 11:47 PM
  2. bridgeport series 2 interact 4
    Last Post: 05-01-2010, 01:27 AM
  3. bridgeport interact 4 series 2
    By gideon233 in forum Bridgeport / Hardinge Mills
    Last Post: 02-16-2009, 03:05 AM
  4. Bridgeport Series 1 interact tnc 145
    By jaztau in forum Bridgeport / Hardinge Mills
    Last Post: 10-20-2008, 10:12 AM
  5. Bridgeport Series 1 Interact
    By zorba99 in forum Bridgeport / Hardinge Mills
    Last Post: 06-11-2008, 01:59 PM
