603,939 active members*
3,509 visitors online*
    Aug 2007
    10
    Bridgeport R2E4 CNC Mill
    I have a Bridgeport R2E4 CNC milling machine that I just purchased from a local community college. After setting the machine in place I tried to start it and the control panel gave me an error that the axis drive would not enable. I checked the control panel and found that the RC circuit across one of the axis starter coils was blown. I replaced the RC circuit and it burn out again. I cannot find any shorts in the circuit. The coil checks the same as the two remaining axis coils check. Does anyone have any quick things that I can check?
    Rick
    Jul 2009
    219
    Sorry I can't help with your problem but, Try posting in the Bridgeport section and I bet someone there will be able to.
    Regards,
    Eric
  1. Bridgeport R2E4
    By steve ohalloran in forum Bridgeport / Hardinge Mills
    Last Post: 06-21-2010, 09:11 AM
  2. bridgeport CNC R2E4
    By asantos in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-16-2009, 06:40 PM
  3. Bridgeport 1 R2E4 Mill
    By Tommy in forum CNC Machine Related Electronics
    Last Post: 11-18-2008, 03:32 AM
  4. bridgeport 9 r2e4
    By reedmiles in forum Bridgeport / Hardinge Mills
    Last Post: 06-23-2007, 02:07 AM
  5. Bridgeport CNC Mill, Model R2E4, Boss 9 Control
    By Tbucit in forum Bridgeport / Hardinge Mills
    Last Post: 03-18-2006, 04:39 AM
