587,326 active members*
3,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport series I Boss 8.1 R2E3 Imperial and Metric planetary gear Knee dial.
    Jun 2011
    21
    Hi All
    I am hoping some helpful Bridgeport owner can help me here. I have an imperial and metric machine. On the Knee crank there are two dials one that reads in metric 0-2mm and one that reads in imperial (0-100 thou). The imperial dial is driven by an Aluminium disc that is locked in place by a knurled nut. The imperial dial in-turn drives the metric dial with a planetary gear setup so you get 2 readouts. Mine does not appear to be working right. I can disengage it to set the dials to zero but I can't get them to turn with the crank handle.
    Explaining what is and is not happening would take too long so I've done a video here:Bridgeport R2E3 BOSS 8.1 imperial and metric knee dials issue - YouTube
    Has any one seen this set up?
    How is is supposed to work? How are the disc and the imperial ring supposed to mesh? What is the internal knurling on the disc for for or is that a later addition.
    Any help is welcome.
    Alastair
    Jun 2011
    21
    Hi All
    I have had zero response So I am assuming that this is very unique. Below are a few pics for those that dont want to watch videos.
    The Whole thing together
    The large dial and the disc
    Large dial removed showing disc in place
    Locking nut that locks the disc to the shaft. the disc then spins but it does not drive the Outer dial.
    The issue is that I don't know how the large Dial attaches to the Disk to drive both dials round. I am at a loss here anyone who has seen something similar or on another Bridgeport please shout.
    Alastair
  1. Bridgeport R2E3 with VFD. Bridgeport gear, speed and direction settings.
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 04-23-2013, 10:50 AM
  2. Help Bridgeport R2E3 Series 1 Boss 8 - 460 volts to 230 volts
    Last Post: 04-03-2013, 07:23 PM
  3. Need help with Bridgeport Boss 8 Series 2 R2E3
    By clue1005 in forum Bridgeport / Hardinge Mills
    Last Post: 12-17-2009, 06:32 PM
  4. R2E3 series 1 Boss 8 interest
    By s1j1m10 in forum Bridgeport / Hardinge Mills
    Last Post: 08-23-2006, 04:53 PM
  5. Bridgeport R2E3 with Boss 8
    By John Bennett in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2005, 04:06 PM
