587,137 active members*
3,469 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > Bridgeport servo motor repair or replacement
Results 1 to 5 of 5
    Feb 2006
    40
    What is everyone doing when the servo motors go bad? I have several R2E4 series-2 and one series-1 that need motors. Since you can't buy new ones anymore does anyone have a good solution? I have had some repaired for $800.-$1,200.00 but not all are repairable. Series-2 use Sem. Series-1 use CMC or Powertron. Could I still buy the proper motors and encoders separately and connect them? This is a big problem since repair is a gamble even if the motor components are still good.
    Dec 2003
    24223
    You can still get the SEM, they are made by Servo Dynamics now.
    http://www.servodynamics.com/DC_Brush_Motors.html
    They often come up on eBay also.
    Al.
    Albert E.
    Dec 2005
    3319
    An outfit called Clarkson is also the factory authorized warranty/service center for SEM. I had some rebuilt there - pricey but good work and the servos looked and worked like new when I got them back.
    Aug 2005
    1622
    I'll second that! I've had several(4-5) 10-15yr old SEM's rebuilt by Clarkson. Between Milltronics and our Bridgeport EZ-Path that both use SEM servos, Clarkson rebuilds while not cheap, are a slam dunk for trouble free service in the long run.
    I look at it as a case of spending the money once or gamble on spending the money twice if not more, if a cut rate motor damages something else in its system.
    DC
    serov repairs
    We can recharge and realign the servo and repair the drives and encoders. See www.ncservo.com.
    Thank you,
    Eddie
  1. Bridgeport Mill Service and Repair in California?
    By wonder squirrel in forum Bridgeport / Hardinge Mills
    Last Post: 08-07-2018, 03:42 AM
  2. Reliance Servo needed............or repair!
    By tgm in forum Servo Motors / Drives
    Last Post: 04-07-2012, 04:12 AM
  3. CNC motor replacement/repair
    By intellec7 in forum Servo Motors / Drives
    Last Post: 06-29-2010, 02:30 AM
  4. servo repair
    By miljnor in forum Servo Motors / Drives
    Last Post: 02-25-2008, 03:48 PM
  5. bridgeport spindle motor replacement 1phase
    By plascom in forum Bridgeport / Hardinge Mills
    Last Post: 02-25-2005, 03:15 PM
