587,547 active members*
2,994 visitors online*
Results 1 to 6 of 6
    Mar 2012
    378
    Bridgeport servo system
    Just got my first Automation Technologies 1150 in oz servo motor today. Looks to be a good quality motor. Don't have the big power supply for it yet so just temporarily connected it to a small 60V .5A bench supply expecting it to barely run the motor, but it had a surprising amount of torque with that small amperage.
    What surprised me is that this is just a direct drive motor. I am used to servos being a geared motor. Since it is not geared it has hardly any resistance to back driving. Great when I want to use the machine in manual mode, but I am wondering how that will work out on a stopped axis on the machine. I suspect that it will always be trying to back drive, then powering the motor to put it back where it belongs therefore constantly hunting. Don't have that problem much on a geared motor since the gearing keeps it still. Can someone with experience with these tell me how well they just hold in place?
    Jan 2005
    15362
    brian257
    I not quite sure what you are meaning, by hunting back driving
    If you are using the machine in manual with hand wheels, then the power should not be on the motors
    If you are using manual under power, then there should not be any movement from any axes, if they do you will have to tune the drives, No axes should move only if you give it a signal to move
    When you turn the power on for CNC use the motors will/should lock up were ever they are, you then home the machine & you are ready to run
    Mactec54
    Mar 2012
    378
    I was referring to when the machine is in CNC. A stepper has voltage on it when it is stopped so it holds in place. The servo motor has no voltage when it is stopped so it is free to back drive until it gets out of position and voltage is applied to turn it back the other direction hence a cycle of moving slightly then going back to where it was supposed to be. A highly geared servo like a model airplane servo does not back drive much because of the gearing.
    So what I am wondering is if the ungeared servo will be in a constant humm trying to keep position when it is stopped.
    Dec 2003
    24220
    If a servo is tuned properly it will recognize an out of position starting with one encoder pulse, with a torque mode drive, the motor current will be in proportion to the encoder error.
    A servo motor is not 'free to back drive' as there is only zero motor current with zero following error.
    Al.
    Albert E.
    Mar 2012
    378
    So pretty much with the small error values read on the encoder and proportional motor currents it gives a good tight PID loop and will stick where you want it without vibration or hum. I will buy that. Thanks.
    Jan 2005
    15362
    brian257
    As Al The Man has said the servo motor is not free to back drive, This could only happen if the drive was badly tuned, The power supplied to the drive was not correct, or the motor was to small for the job it is doing
    vibration or hum. No this only happens when the drive is not tuned correct
    Mactec54
  1. CMC Tape Twin BTR System DNC to Bridgeport BOSS 5
    By kdhBOSS5VRAM in forum DNC Problems and Solutions
    Last Post: 07-05-2013, 04:21 PM
  2. Y-measuring system defective (Bridgeport Series 2 Interact 4)
    By Robert_Downs in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2009, 12:20 PM
  3. Servo System ?
    By Kencor1 in forum Automation Technology Products
    Last Post: 03-08-2009, 06:43 PM
  4. Bridgeport Lube System
    By kewl_cat in forum Bridgeport / Hardinge Mills
    Last Post: 03-05-2006, 05:54 PM
  5. Servo System Set Up
    By Gorillakilla in forum Servo Motors / Drives
    Last Post: 11-15-2005, 11:04 PM
